98-01 type r front lip hardware
Old May 24, 2004 | 01:59 PM
boost fed ls's Avatar
Default 98-01 type r front lip hardware
I am getting ready to install a type r lip, i was wondering instead of buying the expensive acura hardware, can i go to a hardware store(lows,home depot, ect.) and find the hardware i need? If so, what do i need? Thanks!!
Old May 24, 2004 | 02:09 PM
SuzukaBlueAP2's Avatar
Default Re: 98-01 type r front lip hardware (boost fed ls)
hardware? Got get yourself some 3M double sided tape and 2 self tapping screws. That should be more than sufficient.
Old May 24, 2004 | 02:12 PM
Default Re: 98-01 type r front lip hardware (ScreaminTeg)
works for me thanks man
Old May 24, 2004 | 02:27 PM
sys3rror's Avatar
just need a couple of self tapping screws for the side and zip tie the bottom/middle of the lip.
Old May 24, 2004 | 02:41 PM
reza
Default Re: (sys3rror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sys3rror &raquo;</TD></TR><TR><TD CLASS="quote">just need a couple of self tapping screws for the side and zip tie the bottom/middle of the lip.</TD></TR></TABLE>
This should work out fine
Double sided tape is a must.
Old May 24, 2004 | 02:43 PM
slowacura's Avatar
Default Re: (cpr'd.gsr)
didn't use any double sided tape - just 2 screwson each side and it holds well
Old May 24, 2004 | 04:11 PM
Default Re: (inteGSR)
thanks again!!
JDMoneDC5
May 15, 2008 03:59 PM
slvrDC4
Jun 22, 2007 03:27 PM
D for D series
May 10, 2005 03:44 PM
patdemps
Apr 29, 2004 06:11 PM
lessthndan
Oct 8, 2002 08:27 PM
