Swapping pistions and rods?!?
Old May 24, 2004 | 01:43 PM
Chillinit's Avatar
Default Swapping pistions and rods?!?
Sup all,
Did a compression test on my plant and its not well. cyl #4 is at 75!! I pulled my pistons today and found the the ring land is cracked on #4 and #3. So I'm considering slapping in a set up forged pistons and rods at the moment. My question is, If I were to stick with stock bore and change my pistons, rods, connecting rod bearings, main bearings, and do slight hone on the cylinder walls, would this be sufficient?? would I have to rebalance my bottom end? I know I should do a complete build(ie machine shop) however I need to get my car on the road as soon as possible. Any info would help!!
Modified by Chillinit at 12:21 PM 5/25/2004
Old May 24, 2004 | 07:55 PM
Chillinit's Avatar
Default Re: Swapping pistions and rods?!? (Chillinit)
anyone?? i need some advice!!
Old May 24, 2004 | 08:05 PM
sporkcrx's Avatar
I would say that'd be fine. That's basically all I did with my rebuild and it's been fine for thousands of miles.
Old May 24, 2004 | 08:11 PM
boosted_dc2's Avatar
Default Re: Swapping pistions and rods?!? (sporkcrx)
yea just run a hone through it. i deally you want to take it to a machine shop and have them hone it to the piston specs. but just check what the clearances are and you might be okay.
Landon
Old May 24, 2004 | 10:28 PM
gunmetalcivic's Avatar
i did exactly what you have described and honed the block while still in the car. havent had any issues so far.
Old May 25, 2004 | 12:51 AM
89dxhunchback's Avatar
Default Re: Swapping pistions and rods?!? (gunmetalcivic)
Needs rebalenced.
Big rods, different pistons on stock crank ? The "bob weight" is different meaning that the old rotating ***. was lighter basiclly.
"You can drive with your feet, but that don't make it a good f**king idea !!!"-Chris Rock
That's IMO. I'm the honda guy with low compression turbo, what do it know ?
Default Re: Swapping pistions and rods?!? (89dxhunchback)
forgot to subscribe
Old May 25, 2004 | 03:20 AM
Chillinit's Avatar
for the responses....anyone else??
civicdx1
Oct 31, 2015 03:04 PM
kpjo4
Mar 11, 2010 07:56 PM
SiR99
Sep 1, 2006 09:17 PM
Chuji
Oct 31, 2005 12:10 PM
ntegls
Feb 22, 2004 06:11 PM
