engine install problems
i just finished installing my d16a6 into my std hatch...i think i did all the wiring correctly because i get no codes fromthe ecu, the problem is that the engine won't start, what do you think the culprit maybe? if i wired the distributor incorrectly will it show up as a code in the ECU (like misplacing the white wires)? or could it be the injector resistor? i dunno, im stuck! please help!
thanks!
thanks!
detailer67
Apr 22, 2004 08:10 PM
