teg problems: bog, CEL 43, etc.
Old May 24, 2004 | 11:59 AM
integra*RS*'s Avatar
New User
Default teg problems: bog, CEL 43, etc.
Is it natural for a 94 teg(140k) w/ skunk2 ecu to bog: but only before it warms up, when its cold it feels like its dumping a whole lot of fuel = bogs like crazy
Sometimes it thows a CEL 43 = fuel supply: already replaced my fuel filter, checked plugs/wires. At times I wouldn't see it for a week & then out of nowhere, there it is again. Engine restart & its gone again.
ALso, my distributor has this ticking noise (no its not the valves, I've followed the sound & its coming from the distributor).
One more thing, is my speedometer inaccurate because i have a different tranny(99si).
Thanks in advance for the future helP.
-jun
Old May 24, 2004 | 02:21 PM
aznballer's Avatar
im having the same problem, i changed fuel filter also and the 02 sensor
Old May 24, 2004 | 02:33 PM
sPaRk'iT's Avatar
Default Re: teg problems: bog, CEL 43, etc. (integra*RS*)
Try changing your fpr.
Old May 24, 2004 | 04:15 PM
jh4db536's Avatar
Default Re: teg problems: bog, CEL 43, etc. (sPaRk'iT)
maybe you need to lower your fuel pressure via FPR.
Old May 24, 2004 | 06:16 PM
New User
Default Re: teg problems: bog, CEL 43, etc. (jh4db536)
code 43: fuel supply
gone after restart & doesnt come back for a while, maybe aftre a week or a couple of days.
I don't know if should be so concern. I'm also thinking of replacing my o2 sensor w/ a semi new one.
Thanks for the replies.
the bogging: After the car has been warmed up, it seems to run fine. Im not sure if im running too rich or lean. If I get an fpr, at what psi should I set it to. Thanks again.
My distributor: is there something loose in there that I should be tightening up? Kinda has that ticking sound.
91blackEF
Apr 5, 2021 03:23 PM
EFb18b
Aug 2, 2015 04:28 PM
Dubs13
Aug 27, 2009 07:22 PM
dis_epix3
Aug 31, 2006 03:52 PM
IwanAturBo
Mar 16, 2003 06:53 PM
