building a dohc zc was wondering what parts i need to get from what cars
alright i picked up a dohczc and am rebuilding it to have 0 miles. but im not too sure what engines i can use parts off of. i know some of the crx si parts will work but not sure. also i was wondering which intake manifolds i can use. i am looking to totally rebuild it so if anyone can help out let me know. thanks. also if anyone knows where to get some total seals and aftermarket (stage 2 cams) let me know.
From: spinning DnB till your head explodes,jersey/philly
well most of ur parts are gonna be from an 88-89 teg. u can get some parts from a6s. if u want to run a differnt intake manifold im pretty sure ur gonna have to make an adapter plate. but my choice would be the y8 or z6 manifold. and for cams go with exospeed.
heres a starter list for you. Do a search next time you will be surprised what you can find..
Also heres a link to a site that will tell you most of the things you need to know.
http://members.aol.com/_ht_a/nosajuf/nosajuf2.htm
Timing Belt:-----1988 Prelude 2.0-----14400-PK2-004
Timing Belt Cover:
AC Compressor / Parts:-----1989-91 CRX/Civic-----N/A
AC Bracket:-----1988-91 CRX/Civic-----N/A
...The AC Compressor bracket bolts onto the ZC block.
Throttle Body:-----1988-91 CRX/Civic Si-----N/A
ECU:-----1989-91 CRX/Civic Si-----N/A
ECU:-----1986-89 Integra-----N/A
ECU:-----1989-1991 ZC-----N/A
Intake:-----1988-91 CRX/Civic-----N/A
Headers:-----1986-89 Integra-----Any Kind
Headers:-----1988-1991 CRX/Civic-----N/A
Plug Wires:-----1986-89 Integra-----Any Kind
Spark plugs:-----1986-89 Integra----- NGK BCPR6E-11
Distributor Cap:-----88-91 CRX/Civic-----N/A
Distributor Rotor:-----88-91 CRX/Civic-----N/A
Distributor Cap:-----1988 Integra-----30102-PM7-305
Distributor Rotor:-----1988 Integra-----30103-PM5-A05
Head Gasket:-----1988 Prelude-----12251-PM7-003
Intake Gasket:-----1988 Integra-----17105-PG6-S00
Exhaust Gasket:-----1988 Integra-----18110-PG6-003
Water Pump:-----1990 CRX-----19200-P01-004
Oil Filter:-----1988 Integra-----15400-PR3-004
Oil Filter:-----1988-89 Integra-----Fram PH3539A
Oil Pan Gasket:-----1988-91 CRX/Civic-----N/A
Oil Pan Gasket:-----1986-89 Integra-----N/A
ZC Pressure Plate:-----1989 Civic DX-----N/A
ZC Clutch Disk:-----1989 Civic DX-----22200-PM7-J02
Clutch:-----1990 CRX-----N/A
Timing Belt Cover:
you HAVE to use the ZC intake manni as no other models will bolt up. If you need help:
http://www.thezcr.com
