Nioses and Squeeks
Hey everyone. This is my first post here at Honda-tech. My question is this....
I have a 94 Civic, Excellent condition. I have about half a break pad left, but I noticed last week the front wheels have a sort of rubbing sound when I make a turn at higher speeds (like entering a highway on an onramp) Could this be the breaks making this sound or could it be a problem with the routers.
What do you think?
-Rob
What do you think?
-Rob
Welcome to H-T.
Please read the forum Rules and Guidelines, and respect them.
https://honda-tech.com/zerothread?id=797969
no. thats probably your tires rubbing against your fenders. how low is your car?
No modifications to car at all. The height is the same as when it was purchased in 1994. The tires are new. I noticed the sounds shortly after the new tires were put on.
Do you think it has something to do with the new front tires?
What kind of tires did you put on?
If you started to hear this noise after the tires were put on i'd say it's the tires. Especially if you're at stock height.
It's wierd, they are the same tires I have been putting on since day one....Im not sure of the Model # but they are Michelins. Front 2 are new and rear are not. i still have some tread left on the rears. Had the front end aligned and everything. Any suggestions. Thanks for all your help guys.
go to where you got the tires from and tell them you been having problems
usually there is a good person there willing to help cause you just got tires mounted there and they should be able to tell you what the problem is
ekcivic9
Oct 15, 2005 01:49 PM
