Can ITR hubs/bearings be pressed into DA/DC rear trailing arms???
Yes they can! They have the same part number. I am curently running DC/DA bearings on my ITR, no problems at all!
Thank you. But is there any difference in the DA trailing arm that would not allow ITR hubs to be installed in them?
yes john. the itr rear spindle is 5mm longer (gives the R a 10mm wider track).
i was looking into this too. just gonna try and find some ITR/CTR rear trailing arms.
5mm longer in the rear??? same Diameter???
Is this the same for the fronts??? Outer bearing race diameter the same from ITR to DA>?
Need to find out ASAP!!
Guest
Posts: n/a
the bearing diameters are the same for the front, the inner diamerter is the same in the back, from itr to base model, the spindle shaft is (as was stated) slightly shorter on the DA/DC than the ITR, the nut will thread but not as far and reliabliity becomes on issue, to correct the problem you could use thinner washers behing the nut.
outer diameter of the ITR rear bearings is bigger than other models.
