crazy tach
Old Nov 8, 2001 | 02:17 PM
B6teen's Avatar
Default crazy tach
the tach on my crx goes crazy when i gun it. it jumps aroung like crazy impossible to read but when im crusing it's normal but will sumtimes jump a little. i asked a honda tech at a dealer and he said it was the ignitor also when im crusing under 4000 rpms the motor sputers, the dealer also says it's related to the ignitor i was thinking i was getting to much fuel. any info would be great thanks
Old Nov 8, 2001 | 02:23 PM
bigrob119's Avatar
Default Re: crazy tach (turborex)
Probably need a new distributor, I had the same bogging problem and the dist. took care of it. Good luck.
Old Nov 8, 2001 | 03:21 PM
cbrman's Avatar
Check the connectors on the ignitor (inside the distributor) take a look at this pic. You can see a few of the wires that go to the ignitor on my old distributor. (something was making a rust powder all over it??? it ended up being a rusty screw head being ground up in the dist gear) If that does not fix it, the ignition unit in the steering column can cause the same thing. Other symptoms will be car dying and hard time starting the car. (turning it over like 10 times to start it) The solder joints melt and actuall connect more than one contact point. That is what happend in my case.
Steven
Old Nov 12, 2001 | 05:03 AM
keithv's Avatar
Default Re: crazy tach (DOHC DX)
Excuse my ignorance, but what part is the ignitor? I have a jumpy tach and took my distributor off this weekend. I looked at all the parts and everything looks ok (to me). I want to try and tighten the connections on the ignitor to see if that helps...
Thanks!
Old Nov 12, 2001 | 05:08 AM
Trinity's Avatar
Default Re: crazy tach (breaka_1_9)
ok this happened to me and the shaft that goes into the dizzy the bearing went out. i mean you couldn't turn it at all. so we rebuilt one with parts from another one. sometimes the sensors can come loosed too but if you can't turn that shaft by hand i bet you it is that bearing
Old Nov 12, 2001 | 11:20 AM
Frosty_spl's Avatar
Default Re: crazy tach (Trinity)
take off the cap, and the plastic thing behind the rotor, there is a blue wire thats for the tach, make sure it has a good connection. that should help your jumpy tach.
s13hero
31
Jun 17, 2016 06:43 AM
usafhanda
Mar 14, 2012 10:29 PM
De_tour
Dec 15, 2005 06:59 PM
hybridbmw
Jul 15, 2002 12:59 PM
B20zvtecek
Jun 24, 2002 06:47 AM
