settings on skunk 2 stage 2 cams...
Old May 24, 2004 | 05:59 AM
silverb18c1's Avatar
Default settings on skunk 2 stage 2 cams...
What settings are you running for these cams... Just put some in my b18c and I want it to run fairly smooth till I get it to the dyno for some tunning?..
Old May 24, 2004 | 06:20 AM
Ekfoe's Avatar
Default Re: settings on skunk 2 stage 2 cams... (silverb18c1)
settings?? be more specific
Old May 24, 2004 | 06:50 AM
Default Re: settings on skunk 2 stage 2 cams... (Ekfoe)
cam gear settings for the intake and exhaust...how many degrees advanced or retard on each for a decent idle...
Old May 24, 2004 | 07:44 AM
andrewasf77's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">cam gear settings for the intake and exhaust...how many degrees advanced or retard on each for a decent idle... </TD></TR></TABLE>
the idle should be decent without touching them. i wouldnt move things around too much without being on the dyno
Old May 24, 2004 | 08:43 AM
DEVIOUS_EG*'s Avatar
Default Re: settings on skunk 2 stage 2 cams... (andrewasf77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewasf77 &raquo;</TD></TR><TR><TD CLASS="quote">
i wouldnt move things around too much without being on the dyno</TD></TR></TABLE>
Old May 24, 2004 | 08:57 AM
Default Re: settings on skunk 2 stage 2 cams... (DEVIOUS_EF*)
Thats pretty understandable.. I was under the impression it would run like crap till I got it tuned.. I live three hours away from the nearest dyno and I have an appointment in two weeks.. So you think it will be safe to drive it there on stock settings?... I guess there would be too many variables to consider also with what I have and other people are running right..
Old May 24, 2004 | 10:07 AM
TRuST's Avatar
Try +2 on both cams.
Old May 24, 2004 | 01:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Thats pretty understandable.. I was under the impression it would run like crap till I got it tuned.. I live three hours away from the nearest dyno and I have an appointment in two weeks.. So you think it will be safe to drive it there on stock settings?... I guess there would be too many variables to consider also with what I have and other people are running right..</TD></TR></TABLE>
i had my Stg 2's in for a month before going to a dyno. you should be ok without running the thing super hard.
Old May 25, 2004 | 12:14 AM
Ekfoe's Avatar
yeah you can run them for a while but they wont generate that much power without dyno tuning............my base run was 158 , after tuning i got 195
Old May 25, 2004 | 12:20 AM
VAAJ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekfoe &raquo;</TD></TR><TR><TD CLASS="quote">yeah you can run them for a while but they wont generate that much power without dyno tuning............my base run was 158 , after tuning i got 195 </TD></TR></TABLE>
wow, thats impressive#. I would like to know what did you use to tune these cams.
Old May 25, 2004 | 09:30 AM
Ekfoe's Avatar
Default Re: settings on skunk 2 stage 2 cams... (VAAJ)
hondata s200 and a dynapack
Old May 25, 2004 | 10:56 AM
Big Poppa Pump
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekfoe &raquo;</TD></TR><TR><TD CLASS="quote">hondata s200 and a dynapack</TD></TR></TABLE>
Im calling you out for a GRAPH FOOL
Old May 25, 2004 | 11:55 AM
Ekfoe's Avatar
Default Re: settings on skunk 2 stage 2 cams... (Big Poppa Pump)
i had my engine rebuilt all at once including the stage 2's so it wasnt just the cams that were installed it was a bunch of ****, but i was using that as an example of the difference between a car that is tuned and one that is not. I had a lot of things done at once and after it was tuned it was night and day from that point.
hondaboyB18C1
33
Sep 26, 2007 09:07 PM
an2ny888
Apr 4, 2006 07:18 AM
bootlegtrader
Oct 25, 2005 05:30 PM
ricebowl
Jun 29, 2005 01:17 AM
BuiltTurboCoupe
Sep 22, 2004 08:47 PM
