b18a1 trouble
Old May 23, 2004 | 09:57 PM
LisaCivic's Avatar
Default b18a1 trouble
i got the engine in, it starts but have few things happening
it idles high, but when i move a vacuum line it runs good but then has problems when using the throttle, it struggles
then when i took it for a little test drive in 2nd gear it maxed out at 25 mph
i think it's the vacuume lines
anyone know what to check to get the car running a little better so i can get it to a mechanic for a tune up
Old May 23, 2004 | 10:27 PM
LisaCivic's Avatar
Default Re: b18a1 trouble (LisaCivic)
can anyone provide a close up pic of the vacuum lines on their b18a1, that might help sort this out
Old May 23, 2004 | 10:30 PM
Malgerus's Avatar
Any codes? How'd the shift linkage work for you??
Old May 23, 2004 | 10:36 PM
LisaCivic's Avatar
Default Re: b18a1 trouble (Mr. S)
ecu not giving codes either, the shift linkage worked good, a little tight though but it works
Old May 23, 2004 | 11:49 PM
hahagasdcrx's Avatar
did you remove both dust caps off the backside of the wheel bearings? They will keep your cv axles from moving freely. Acceleration feels like your brakes are locked thats how i would describe it. Also your engine might run a higher rpm when u first crank it up then will go down when its warmed up.
Old May 24, 2004 | 11:32 AM
LisaCivic's Avatar
Default Re: b18a1 trouble (90crxzcgasd)
i did both dust caps that works fine, it just the vacuum lines i think, its just rinning like ****, when i move a couple of the vacuum lines the rpm goes down and sounds good, but then when using the throttle it starts have problems, the vacuum lines that i have moved may cause that, but i do not know, then there is a wire that is loose somewhere, it kills the engine when moved, i will find that
just need a pic of what someone else did for there vacuum lines then go from there
Old May 24, 2004 | 05:17 PM
LisaCivic's Avatar
anyone have a pic of this
Granulatedsugar
Classic Hondas
Aug 30, 2016 05:16 AM
E Town DSM
Nov 5, 2012 06:03 AM
92civicx
Mar 4, 2009 06:28 AM
redline870
Dec 3, 2008 05:22 PM
LisaCivic
May 22, 2004 11:43 PM
