90 Accord H22 fuel problems
Old May 23, 2004 | 08:29 PM
Baltz's Avatar
Default 90 Accord H22 fuel problems
I just got the motor swap and the fuel lines dont match up at all. Anyone else have this problem? Is there any place that makes the lines? Or is there any place that I can buy the fittings from because I can make the hose and press it. Any help would be appreciated
Old May 24, 2004 | 04:27 AM
jakks20's Avatar
Default Re: 90 Accord H22 fuel problems (4th gen accord)
Use your F22 fuel rail.
Old May 24, 2004 | 04:36 AM
H2290's Avatar
Default Re: 90 Accord H22 fuel problems (jakks20)
It's too short. You just need to lengthen it somehow. I bought some fuel line and then some high pressure fittings and cut my F22 fuel line and used each side of my F22 line on the end of my new longer fuel line.
Old May 24, 2004 | 05:09 AM
jakks20's Avatar
Default Re: 90 Accord H22 fuel problems (H2290)
If you put your F22 fuel rail on the H22, how can it be too short???????? The fuel rail is in the exact same spot.
Old May 28, 2004 | 10:02 AM
Baltz's Avatar
The line is not long enough it has to go all the way across the engine bay instead of the old layout. I just finally found someone that makes custom lines. It was $70 so problem solved now. Well not really.....distributor locked up. Steve sent me another one next day air
Old May 28, 2004 | 11:34 AM
ZigenBallz's Avatar
rhdcivic05
Aug 31, 2009 09:13 AM
SixguN
Feb 28, 2005 07:45 PM
98HB
Mar 25, 2003 02:37 PM
sikciv666
Mar 4, 2003 06:11 PM
poison
Sep 8, 2002 11:10 PM
