installing a hondata gasket on a 97+ prelude
if you're a base model, its pretty easy, should take a first timer about .... 2 hours?
took me 1.5 hours first time around.. 1 hour 2nd time around
its easier to take it out if you take off the TOP half of the intake manifold first, then work ur way around it.. then take the botteom half out last.
I don't knwo how much room there is in a 5th gen but in my 4th I had to take the top half off first and then the bottom... The only part that really sucks is the 5 bolts or so on the bottom of the manifold... Good luck
i had to modify mine. apparently an operator loaded the material into the cnc incorrectly. some holes for the studs needed slotting to fit correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote"> why would the SH be so different, especially around the IM?</TD></TR></TABLE>
to get to the bolts under the IM...you have to come up from under the car to get them...and well what do ya know....the ATTS is there...so you would have to remove the ATTS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Si »</TD></TR><TR><TD CLASS="quote">i had to modify mine. apparently an operator loaded the material into the cnc incorrectly. some holes for the studs needed slotting to fit correctly.</TD></TR></TABLE>
mine slid on, but bairly...i had to dremel out a good bit around the runners though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenPoweredLude »</TD></TR><TR><TD CLASS="quote">to get to the bolts under the IM...you have to come up from under the car to get them...and well what do ya know....the ATTS is there...so you would have to remove the ATTS</TD></TR></TABLE>
No need, you just have to use the correct extensions. Though I never got that vacuum box for the secondary runners bolted back in (need a second pair of hands to help position it) but you can easily do it on a Type-SH with the motor in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote">
mine slid on, but bairly...i had to dremel out a good bit around the runners though.</TD></TR></TABLE>
yeah. when i test fitted mine the ports were off so much that i questioned even using it at all. it sat high on the roof and material was protruding into the port from the bottom. deffinately a potential restriction. it easily could have hurt more than helped if i didn't modify it. when tightening the IM nuts i had to hold the gasket up on the timing assembly side to keep it from falling too low, after slotting them.
If anyone else is installing one, CHECK FOR PROPER PORT ALIGNMENT FIRST! otherwise your just wasting money.
Can anyone else verify the following statement in reference to installing the hondata IM gasket in a SH?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer »</TD></TR><TR><TD CLASS="quote">
No need, you just have to use the correct extensions. Though I never got that vacuum box for the secondary runners bolted back in (need a second pair of hands to help position it) but you can easily do it on a Type-SH with the motor in.</TD></TR></TABLE>
Please post if you have any experience!
had mine installed in less than 2 hours. to remove the nuts, sit on top of the battery and stuff your left arm under the im. for the other side stuff your right arm under the im. just move things out of the way. it's not that hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happylude »</TD></TR><TR><TD CLASS="quote">had mine installed in less than 2 hours. to remove the nuts, sit on top of the battery and stuff your left arm under the im. for the other side stuff your right arm under the im. just move things out of the way. it's not that hard.</TD></TR></TABLE>
Cool, thanks. I didnt want to remove atts to do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">stuffing your arm under there only works if its skinny enough...</TD></TR></TABLE>
I get my little brother to do it, he's only 12 and has small arms lol.
im about to do the same gasket install, but im planning on removing the secondary butterflies at the same time. im installing hondata this week also and im switching from my obd-II to a p28 (i was too cheap/impatient to find a p72 obd-I) and i figure since i dont have control over the 2nd butterflies ill just remove them. how labor intensive is this? tips? advice?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">there's just a lot of junk to remove and it's tough to get in there. Heh that's why I installed mine when the motor was out.
same
</TD></TR></TABLE>same
B18Redline
Aug 24, 2004 04:58 PM
