Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Hoosiers up front kumhos in rear how bad could it be?
Old May 23, 2004 | 07:26 PM
mgast's Avatar
Default Hoosiers up front kumhos in rear how bad could it be?
right know the car is up for sale but I am still having such a blast driving it at local autox events, but there is a couple of bigger events coming up, and I would really like to see what the car can do. my question is right know I am running 235/45/13 v700 all around the car on a 7.5 inch rim, how twitchy/tail happy could the car really be If I put some 225/50/13 hoosier's a3s04 on the front and left the v700's on the rear? I can get some lift throttle oversteer on faster turns but on slowspeed turns the car will push if you enter too hot, maybe this is just what it needs. any input would be appriciated.
later
matt
Old May 23, 2004 | 08:15 PM
Slow_Em1's Avatar
Default Re: Hoosiers up front kumhos in rear how bad could it be? (mgast)
i would try to stick with the same tire all around, but its up to you and how your suspension is set up.
Old May 23, 2004 | 08:35 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgast &raquo;</TD></TR><TR><TD CLASS="quote">right know the car is up for sale but I am still having such a blast driving it at local autox events, but there is a couple of bigger events coming up, and I would really like to see what the car can do. my question is right know I am running 235/45/13 v700 all around the car on a 7.5 inch rim, how twitchy/tail happy could the car really be If I put some 225/50/13 hoosier's a3s04 on the front and left the v700's on the rear? I can get some lift throttle oversteer on faster turns but on slowspeed turns the car will push if you enter too hot, maybe this is just what it needs. any input would be appriciated.
later
matt</TD></TR></TABLE>
The Hoosier tire will still push if you enter too hot. A sticker compound won't save you from overdriving. IMHO, if you're used to the kumhos and you're on your way to a big event, stick with what you know. Otherwise, run Hoosier's all around. It's not just a matter of one sticking better than another, both tires behave a little differently.
Old May 23, 2004 | 09:26 PM
TeamSlowdotOrg's Avatar
Default Re: Hoosiers up front kumhos in rear how bad could it be? (travis)
FYI: I went from the Yokohama A032R-S (very similar to the Kumhos in behavior) to the Hoosier R3S03 in the same size (sortof, the hoosiers are way wider of course) and just today finally figured the Hoosiers out, 10 runs later. I think I adapt pretty quickly to new cars/setups. So, if you're headed to a big event on new tires with no experience on them, well, good luck! I certainly wouldn't want to.
And like Mr. T said, entering too hot is entering too hot. Try slowing down.
Old May 23, 2004 | 10:03 PM
Warren's Avatar
Wrong-Way Wang
I've done it before. It's a lot of fun There's something else wrong in the setup if you need to take this sort of drastic measure though.
Warren
Old May 24, 2004 | 04:19 AM
00R101's Avatar
Default Re: Hoosiers up front kumhos in rear how bad could it be? (Warren)
Your tire/suspension system is far more complex then overall stick. What's important is transitional behavior; how quickly the tire reacts to changes in direction; how they react when their limits are exceeded; how quickly they "come back" after being exceeded. The Hoosier and the Kumho are different enough that the combination is sure to be worse and less predictable than a full set of either. This is a bad idea.
Old May 24, 2004 | 06:27 AM
PseudoRealityX's Avatar
Default Re: Hoosiers up front kumhos in rear how bad could it be? (TeamSlowdotOrg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamSlowdotOrg &raquo;</TD></TR><TR><TD CLASS="quote">I think I adapt pretty quickly to new cars/setups. So, if you're headed to a big event on new tires with no experience on them, well, good luck! I certainly wouldn't want to.
And like Mr. T said, entering too hot is entering too hot. Try slowing down. </TD></TR></TABLE>
Pffft... it's more fun to show up in new cars/setups at big events.
It's a Challange.
Old May 24, 2004 | 07:02 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">I've done it before. It's a lot of fun There's something else wrong in the setup if you need to take this sort of drastic measure though.
Warren</TD></TR></TABLE>
yes tons of fun......try some v700 with street tires in rear.....and they say you can't drift a front wheel drive in auto x without ebrake!!!!!
Old May 24, 2004 | 07:10 AM
Hunter's Avatar
Default Re: Hoosiers up front kumhos in rear how bad could it be? (chad)
we ran an auto-x in a '95 civic coupe w/ b16 swap... stock suspension... 205 azenis up front with 175 winter tires in the rear..... HOLY DORIFTO BATMAN! it was almost uncontrolable!
Old May 24, 2004 | 07:40 AM
jsi's Avatar
jsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
A guy at our last event with a DS Mazdaspeed Protege was running brand new 225 A3S04 in front and stock tires in back (whatever they are), cuz of serious rubbingg issues with 225s S04s in back. Said the car was far more controllable than he expected. Placed in top 4 in DS with some stiff competition too... He'll go with 205s in back...
crx12
May 1, 2008 10:24 PM
junkyard racer
31
Sep 12, 2006 11:27 AM
577HondaPrelude
145
Oct 27, 2005 07:55 PM
m00nr0ck Si
Suspension & Brakes
10
Oct 11, 2005 08:15 PM
IntegraBoy04
56
Jan 21, 2005 06:12 PM
