Oil leak on timing belt side of the block
Old May 23, 2004 | 07:12 PM
95 integra's Avatar
Default Oil leak on timing belt side of the block
Edit: Problem fixed with a new head gasket.
Coming from this area of my block. Rebuilt the motor not to long ago, used a new headgasket and its been leaking oil ever since. At first I thought it was because I used a "new"(used) head and I thought it might be warped...so I put my old head back on, but it still leaks. Seems to be an oil feed in the block that just stops there, so Im assuming its caused by a bad headgasket???
Modified by 95 integra at 8:50 PM 6/6/2004
Old May 23, 2004 | 07:51 PM
Quiks66's Avatar
Default Re: Oil leak on timing belt side of the block (95 integra)
I'm having the same problem. Oil leaks down the front side of the block and down the AC bracket. I can't seem to find exactly where it's coming from, but I'm losing quite a bit of oil. BUMP to see if anyone else has had this same problem and figured out how to fix it. By the way, I have a B18A block with a B16A2 head (LsVtec).
Old May 23, 2004 | 08:05 PM
Dan GSR's Avatar
a lot of oil? or just a little?
Old May 23, 2004 | 08:10 PM
Danger's Avatar
Default Re: Oil leak on timing belt side of the block (Dan GSR)
did you resurface the head ?
Old May 23, 2004 | 08:17 PM
ILuvJDMITR's Avatar
Default Re: Oil leak on timing belt side of the block (JonnyDanger)
I suppose i should check my block there as well...
Old May 23, 2004 | 08:41 PM
95 integra's Avatar
The 96 head I first put on was checked for straightness and came back ok, so I dont think thats my problem. Originally, with the 96 head, I was leaking a ton of oil, but now that im back to my 95 head its a very slight leak. The funny thing is after I put the 95 head on I drove about a 1000 miles without any leaking or very very little and now in the past 400 miles I leaked about a quart.
Old May 23, 2004 | 08:48 PM
MasterSaif's Avatar
i have the same problem, the side were the vtec is i see leaks very small drops ,not enough to notice the loss between oil changes,but i noticed on my block the oil stains,what could that be .
Old May 23, 2004 | 08:54 PM
95 integra's Avatar
Default Re: Oil leak on timing belt side of the block (MasterSaif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterSaif &raquo;</TD></TR><TR><TD CLASS="quote">i have the same problem, the side were the vtec is i see leaks very small drops ,not enough to notice the loss between oil changes,but i noticed on my block the oil stains,what could that be .</TD></TR></TABLE>
Thats a cam seal leak.
Old May 24, 2004 | 09:06 AM
95 integra's Avatar
comeon, I know somebodys had this problem before.
Old May 24, 2004 | 07:44 PM
Quiks66's Avatar
Anyone have this problem before? Please...
Old May 24, 2004 | 07:52 PM
4crx4me's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">
Thats a cam seal leak.</TD></TR></TABLE>
Cam seal. Or, the valve cover gasket, did you a get new one or did you reuse the old one?
Dan GSR's Avatar
Default Re: Oil leak on timing belt side of the block (Quiks66)
check to see if your headgasket is on upside down
if it was, then its no good now
you should see the part number stamped on the exhaust side, closest to the transmission...the part numbers stick out a bit
Old May 24, 2004 | 07:54 PM
m R g S r's Avatar
Default Re: Oil leak on timing belt side of the block (4crx4me)
I've heard of major oil leaks due to the headgasket being on upside down. Check out the all motor fourm of the forced induction fourm, everyone in there tears motors apart and has small problems like this.
Old May 24, 2004 | 08:39 PM
NightRiderS2K's Avatar
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4crx4me &raquo;</TD></TR><TR><TD CLASS="quote">
Cam seal. Or, the valve cover gasket, did you a get new one or did you reuse the old one?</TD></TR></TABLE>
It is a possibility it might be the cam seals...else did you use hondabond as a precaution when you reinstalled your gasket?
-NRG
Old May 25, 2004 | 12:02 AM
Boofster's Avatar
Default Re: Oil leak on timing belt side of the block (NightRider-gsR)
Small possibility it may be that your valve cover is not tight enough, leaky valve cover gasket, or your spark plugs are not tight enough.
Old May 25, 2004 | 07:16 AM
95 integra's Avatar
Default Re: Oil leak on timing belt side of the block (Boofster)
Well I ordered a new head gasket yesterday, mainly because thats the only thing it could really be. Yes I did install it backwards(like a dumbass) the first time, but thats causes a huge oil leak and apparently screwed my gasket up...or so I hope. I used hondabond and torque my valve cover(and every other bolt on the engine) to spec and its not leaking from that area, so I assure you thats not my personal problem. My head gasket will be here tomorrow so Ill let you know if that fixed it on thursday.
Old May 25, 2004 | 05:57 PM
AllmansDB8*'s Avatar
Your oil leak is coming from the cam seals that are located around
the camshafts. You have a cam plug that is located next to the distributor,
and when it leaks oil it pours down the block and the tranny. And you have
cam seals that are near the timing belt, and when it leaks oil it pours exactly
where you circled. - The timing belt needs to come off, and you need to remove
the main caps, and camshafts to replace them.
Old May 26, 2004 | 07:26 AM
95 integra's Avatar
Default Re: Oil leak on timing belt side of the block (StealthGPDB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StealthGPDB8 &raquo;</TD></TR><TR><TD CLASS="quote">Your oil leak is coming from the cam seals that are located around
the main caps, and camshafts to replace them.</TD></TR></TABLE>
No Im pretty sure its not coming from there....I will double check today when I rip the motor back down, but I checked that last time and that entire side of the motor was completely dry. Also I put in new cam seals.
Old May 27, 2004 | 09:52 AM
Sometimes if they are not installed properly on the camshafts, they will pop
right out. So just make 100% sure that it's not leaking from there!
Old May 27, 2004 | 04:06 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StealthGPDB8 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes if they are not installed properly on the camshafts, they will pop
right out. So just make 100% sure that it's not leaking from there!</TD></TR></TABLE>
Yea, sorry they were in there tight when I ripped it apart. Finally got my new head gasket it and everything back together....still waiting to take it out for a spin.
Old Jun 4, 2004 | 10:53 AM
JDM_Honda_Fiend's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Thats a cam seal leak.</TD></TR></TABLE>
Old Jun 6, 2004 | 05:51 PM
95 integra's Avatar
Default Re: Oil leak on timing belt side of the block (JDM_Honda_Fiend)
How many times must I say the cam seals were brand new and were installed properly...checked the other day when I ripped the motor apart and they were still in place and there was no oil on that entire side of the block/head. Replaced my head gasket and doesnt seem to be leaking anymore.
Old Jun 14, 2004 | 04:50 AM
grlstockb18c1's Avatar
Hey i just noticed the same thing with my car too. But my oil is leaking on the otherside. Where the engine code is?? People are saying that i need a new headgasket...?? SO how much is this going to run me? ( I heard its the labor thats the killer) **sighs** Thanks
Old Jun 14, 2004 | 05:22 AM
mrctr's Avatar
cam seal...use a new one and use honda bond or kragen bond....around the seals and the corners of the valve cover gasket to enhance adhesion....
Old Jun 14, 2004 | 07:38 AM
95 integra's Avatar
Default Re: Oil leak on timing belt side of the block (grlstockb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grlstockb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Hey i just noticed the same thing with my car too. But my oil is leaking on the otherside. Where the engine code is?? People are saying that i need a new headgasket...?? SO how much is this going to run me? ( I heard its the labor thats the killer) **sighs** Thanks</TD></TR></TABLE>
Sounds like a cam seal to me too. I still cant figure out why my headgasket was leaking where it was...it was an oil return, so its not like the oil was pressurized and needed a good seal.
