Crx idle is low when a/c is on? IDEAS?
Old May 23, 2004 | 06:50 PM
DsMWookie's Avatar
Default Crx idle is low when a/c is on? IDEAS?
The idle drops down real low when I turn the a/c on its a HF crx with 146,000 miles any ideas as to how I can fix this?
I already tried bumping the idle up but that didnt work
Old May 23, 2004 | 09:04 PM
sit220's Avatar
Default Re: Crx idle is low when a/c is on? IDEAS? (FMX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMX &raquo;</TD></TR><TR><TD CLASS="quote"> its a HF crx with 146,000 miles </TD></TR></TABLE>
no wonder
Old May 24, 2004 | 01:01 AM
DsMWookie's Avatar
Default Re: Crx idle is low when a/c is on? IDEAS? (sit220)
cmon now factory car didnt idle like that........think bad pcv valve gimme someuseful info...
Old May 25, 2004 | 08:14 AM
DsMWookie's Avatar
ttt
Old May 25, 2004 | 08:38 AM
d15maverick's Avatar
Bad EACV?
Old May 25, 2004 | 08:44 AM
crx_88_si's Avatar
ok. you might have to do some testing here. but the ECU can tell when the A/C is on. Find out which wire that is and make sure it's connected properly. (Helms). Also your IACV (aka EACV) could be bad..
IACV affects this because when the ECU see's that the AC is on it opens the IACV to let more air into the engine.
Does your engine idle really low under heavy electrical load? (High beams on w/ rear defroster?)
Mine did the same thing. I replaced the ecu and it works fine now. It used to idle at like 400rpm w/ AC or High elec load. Now with the new ecu its rock solid @ 850rpm
Old May 25, 2004 | 02:24 PM
DsMWookie's Avatar
Default Re: (crx_88_si)
Its not real low but like 700-550rpm and i dunno dont use my brights much but defroster never boggs it down just when ac is on Ill try IACV
crxguy406
Jun 22, 2015 08:51 AM
avrfan
10
May 11, 2015 11:41 PM
downsycrx
Nov 14, 2006 04:53 PM
91 ef sedan
Dec 16, 2005 12:37 PM
teamorange
Apr 25, 2005 10:23 AM
