need help with stock RPM gauge
i picked up a 94+ integra cluster up the other day from a buddy of mine in canada......so it has KPH instead of MPH
my question is i know its not a GSR cause the red-line is at 7000 ........ was wondering if i could put a stock rpm gauge out of this GSR cluster i have sitting there cause the speedo on that one is broken........
will the gauge work fine and show me the correct RPM's iam at?
anyone else ???????????????
i would change the speedo's but the GSr cluster is totally messed (case) so though it might be easy just doing the tach swap
Its going to be three screws on the back either way.
Dont bother trying to change faces, you will brake the
needle off. Its a hit or miss and I usually miss when
I try to do it.
I try to do it.
361 accord
Feb 2, 2009 06:14 PM
People_Mover
Jun 29, 2004 12:21 AM
