need help with gc/koni installation!
take the little white plastic washer thing and put it on. it should sit on the base of the body of the shock.
then you put the bumpstop on, the shaft is a bit bigger, so squeeze it over that hard "nub" on the shaft so the top of the bumpstop is flush with the top of the nub.
then you stick a washer on top of that.
then the shock hat thing.
then another washer.
then two nuts. tighten.
If you use the stock bumpstops your going to have to cut them, at least I had to on my 00 Si. Only bolts are the mounting ones in the engine bay and rear mounts, should be easy to find and someone here must know the size.
Jer'rome
Jul 20, 2004 10:16 AM
