Rear swaybar mount holes on EG
Old May 23, 2004 | 03:46 PM
DaiJekBok's Avatar
Default Rear swaybar mount holes on EG
On my 92 Si, the two holes in each side of the rear subframe that the rear swaybar brackets mount to are not threaded and do not have any weld-nuts attached to the other side. As such, I have no way of securing the swaybar to the subframe. Everything I've read has led me to believe that this was a true bolt-on application -- so is my car an odd duck or is it just understood that you have to buy some nuts as well? Do you use washers on the backside too?
Thanks!
Old May 23, 2004 | 03:49 PM
cxSHOE's Avatar
Default Re: Rear swaybar mount holes on EG (DaiJekBok)
just use a nut and washer. it is a true bolt on.
Chewy Built !
Mar 16, 2010 08:08 PM
DavidTurbo
Apr 14, 2003 02:47 AM
