obd 1 - obd 2 SMOG QUESTION "HELP"!!!
Old May 23, 2004 | 03:08 PM
choytim's Avatar
Default obd 1 - obd 2 SMOG QUESTION "HELP"!!!
Im running a 95 GSR motor in a 98 Hatch, everything is stock. Need to pass smog...
My question... if I bring my car in into a smog place would they do a ODB check?
Ive heard they plug in something, into my lower dash. Wonder what is that for?
Any suggestions or answers?
Old May 23, 2004 | 03:24 PM
EG TYPE-R's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (choytim)
first of all a smog place should not pass your car with an uncertified (BAR) swap.
secondly a ref will not pass your swap because the motor is older than your car.
so that pretty much screws you over
swaps need to be the same year or newer than the car they are going into
oh and lastly the thing they plug into your lower dash (underneath the dash) is called the obdII datalink connector and is there so that you can pull codes and test solenoids and many other very usefull things but makes it a pain for us swap guys to do certain things.
good luck
misha
Old May 23, 2004 | 06:52 PM
pornstarSR's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (EG TYPE-R)
yeah misha
Old May 23, 2004 | 07:03 PM
choytim's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (pornstarSR)
Other words there is no way around it? Do they always do the OBD2 test.. when they do the smog?
Any info will help thanks..
Old May 23, 2004 | 09:23 PM
pornstarSR's Avatar
now they do whats called a readiness test... which checks the ecu, and checks some systems...
if the ecu is not obd2 it will not pass this test
Old May 24, 2004 | 02:23 AM
choytim's Avatar
Basicly im **** out of luck... Huh?
OK.. what if I plug in a OBD2 computer, can I pass?
Old Jun 1, 2004 | 10:17 AM
choytim's Avatar
I still need that SMOG.. someone please help.. PM ME
Old Jun 1, 2004 | 11:43 AM
FBP Si 2000's Avatar
I need smog too...but they do plug in some **** under the dash...I think they have a way to bypass it...but I'm not too sure.
Old Jun 1, 2004 | 11:44 AM
B2FiNiTY's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (FBP Si 2000)
Your SOL. Sorry dood.
Old Jun 1, 2004 | 05:05 PM
choytim's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (B2FiNiTY)
YOU CAN **** OUT OF LUCK ONE MORE TIME....!
Old Jun 7, 2004 | 01:55 PM
choytim's Avatar
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 7, 2004 | 01:57 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choytim &raquo;</TD></TR><TR><TD CLASS="quote">Basicly im **** out of luck... Huh?
werd!
Old Jun 7, 2004 | 02:16 PM
civic_tuner's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (b_cruz)
know anyone with a 98 or newer gsr? swap the engine and take it to get it bar'ed, then swap you 95 back in and go smog it? will that work for this guy?
Old Jun 7, 2004 | 03:30 PM
Greasemonkey's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (civic_tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_tuner &raquo;</TD></TR><TR><TD CLASS="quote">know anyone with a 98 or newer gsr? swap the engine and take it to get it bar'ed, then swap you 95 back in and go smog it? will that work for this guy?</TD></TR></TABLE>
Yeah that is a whole lot of work though. Better idea is find someone to swap in the 98 engine. Get it bared and just keep that sucker ahhaaha.
Old Jun 7, 2004 | 03:36 PM
degooser's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (Greasemonkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greasemonkey &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah that is a whole lot of work though. Better idea is find someone to swap in the 98 engine. Get it bared and just keep that sucker ahhaaha.</TD></TR></TABLE>
an even better idea is to find someone with the same year or newer gsr motor trade them for a little, pass smog and bar it...then trade back to get your newer motor back...
Old Jun 7, 2004 | 03:42 PM
94cxhybrid-T's Avatar
New User
you should be able to pass the 95 as a 98 as long as you swap all the components over to the 98. Get the 98 gsr harness, injector clips, intake manifold, TB, ecu, catalytic converter and parts for the evap cannister.
Last june i passed my 97 gsr motor as a 94 by doing the opposite. swapped all the 97 for the 95, since i was already running an obd1 ecu. I passed with flying colors.
Just swap all the needed components and tell them it is a 98.
Old Jun 7, 2004 | 03:48 PM
MR BLACK RAG's Avatar
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (94cxhybrid-T)
go get a illegal smog. i dont even need to bring my car to them
Old Jun 7, 2004 | 04:02 PM
pb16b's Avatar
get a mailing address in another state that doesn't require smog and register your car there... smog problems are no more! florida, michigan for example...
Old Jun 9, 2004 | 03:58 PM
choytim's Avatar
Do SMOG places do VIN# checks?
Old Jun 9, 2004 | 04:07 PM
choytim's Avatar
Do they scan anything on the car?
Old Jun 9, 2004 | 04:44 PM
mrcrash1's Avatar
Where can you get your engine bar'd ? I have never really heard of that. I know you are only supposed to swap in an engine of the same model year or higher. But I don't know how you are to go about getting the swap certified.
Thanks for any info
Old Jun 9, 2004 | 05:12 PM
anothersickhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94cxhybrid-T &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to pass the 95 as a 98 as long as you swap all the components over to the 98. Get the 98 gsr harness, injector clips, intake manifold, TB, ecu, catalytic converter and parts for the evap cannister.
Just swap all the needed components and tell them it is a 98. </TD></TR></TABLE>
That will only work if the technician doesnt read the head for the year numbers. itll tell you what year the motor is just by looking at the head.
Old Jun 10, 2004 | 10:00 AM
Default Re: obd 1 - obd 2 SMOG QUESTION "HELP"!!! (mrcrash1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrcrash1 &raquo;</TD></TR><TR><TD CLASS="quote"> Where can you get your engine bar'd ? I have never really heard of that. I know you are only supposed to swap in an engine of the same model year or higher. But I don't know how you are to go about getting the swap certified.
Thanks for any info</TD></TR></TABLE>
You go to the state ref.
Old Jun 16, 2004 | 03:05 PM
choytim's Avatar
**** OUT OF LUCK... REG IS PAST DUE... im in the ***** now
Old Jun 16, 2004 | 03:13 PM
consolidatedbord's Avatar
Get temporary registration from the DMV. Should be good for at least a month. Not much, but it might give you enough time to get it ready. You can even get these a couple times a row if you have to. I had an old messed up MR2 that I couldn't pass and got temp papers for that POS.
I'm from irvine too. Go to the Costa Mesa DMV. That's what I did... until I sold the car.
