mpfi HELP
Old May 23, 2004 | 02:25 PM
89POS's Avatar
Default mpfi HELP
im throwing codes 4 and 14, would that cause the exhaust manifold to glow red . i took out the cat and gutted it and that seemed to fix the problem for about 20 mins. it got hot again and i turned it off b4 it got the chance to start glowing.
i cant rev pass 2500rpms but im guessing thats bcuz of the 2 codes im throwing. I need to find out what is causing it to get this hot. PLEASE HELP!
Old May 23, 2004 | 02:59 PM
89POS's Avatar
Default Re: mpfi HELP (89POS)
ttt
Old May 23, 2004 | 04:24 PM
civickiller's Avatar
you being not to rev past that is because of the code 4, its one of the crank angle sensor codes. the code 14 is the iacv which is just soemthing to maintain a smooth idle, does yoru car idle rough ?
for the code 4, unplug the big dist plug, the 2 middle terminals, not the one on the side by itself, but the 2 middle terminals, measure the resistance between these terminals, should be 350-550, if that passes then check for continuity between the ground and those terminakls individualy, if there continuity ?
let me know if you pass or which step you fail in
Old May 23, 2004 | 05:20 PM
89POS's Avatar
Default Re: mpfi HELP (civickiller)
actually my idle is as smooth as b4 the swap, steady at 1000 but if i steadyit lower it sounds like its gonna die.
ive had my multimeter sitting so long i forgot how to use it. to check for resistance i set it on OHMS? and....??
and what do you think is causing the exhaust manifold to get so hot?
Old May 23, 2004 | 06:33 PM
-16V-'s Avatar
Did u swap the 2 dizzy wires???
Old May 23, 2004 | 08:32 PM
89POS's Avatar
Default Re: mpfi HELP (-16V-)
yeah i think i did it right. how would i know if i didnt do it right? the car runs just not for long cuz it gets hot and i half to turn it off.
Old May 23, 2004 | 08:46 PM
Bgladfelter's Avatar
Did you switch the TPS wires around? The green and yellow need to swap positions.
Old May 24, 2004 | 02:32 AM
Default Re: mpfi HELP (Bgladfelter)
just make sure that the wires on the dist side, match up with the wires on your harness side. color for color
Old May 24, 2004 | 07:28 PM
89POS's Avatar
any clue on what would cause the exhaust manifold to get that hot? this is what really puzzles me . does this mean the car is running lean?
Old May 27, 2004 | 01:26 PM
89POS's Avatar
ttt
Old May 27, 2004 | 01:43 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89POS &raquo;</TD></TR><TR><TD CLASS="quote">any clue on what would cause the exhaust manifold to get that hot? this is what really puzzles me . does this mean the car is running lean?</TD></TR></TABLE>
If the firing order is wrong that can make the car run like ***. It will do some wierd shizzzzzle and your exhaust tems go up up and UP. I had the wires wrong on a 5.0 V-8 back in ther day... got that manifold glowing white hot!
If you have the thing wired up correctly, and you have the wires on right, then you probably should start looking for a new distributor.
Old May 27, 2004 | 01:58 PM
89POS's Avatar
is there any way to tell how theyre firing? i guess do it over?
HdmPowered
May 4, 2009 01:41 PM
rtpassini
Jun 25, 2004 12:17 AM
TheHatchHog
16
May 15, 2003 11:26 AM
B18C-RnVA
Apr 28, 2002 03:38 PM
