Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Kteller 2.25", 2.5" & 3" Mandrel Exhaust Systems
Old May 23, 2004 | 01:43 PM
KTeller8's Avatar
Default Kteller 3" Exhaust Systems and Mandrel Bends
Kteller 3" Exhaust Systems and Misc. Parts
These systems are available in mild/aluminzed steel and Stainless steel.
All kits come complete with a slip joint feature to ease on install, and also include all hardware. These system require the hangers (we provide) to be touch welded on top and the front flange (we provide) to be installed.
Available for Honda, Acura, Nissan, and other applications
Applications and pricing available on our site. Please click
http://www.kteller.com/store/index.php/cPath/23_35
Performance Mufflers, High flow Cats, Custom Converstion High Flow Cats, Testpipes and Custom Conversion Testpipes available
Downpipe, Exhaust and Intercooler Piping Also Available
We host a large amount of bends and sizes: from 1.75 - 3"
Stainless, Mild/aluminized and 100% aluminum bends and straight sections all available;
Making a Downpipe?
T3 precision laser cut 3/8" flange designed to weld to the downpipe on the outlet side of a T3 or T3/T4 Hybrid turbo
o2 Bungs for sensor and wide bands
Exhaust Flange/gaskets 3 and 2 bolt
throw it on the car and boost away!
click here for prices and options:
Mild and Stainless: http://www.kteller.com/store/index.php/cPath/23
100% Alum for IC piping: http://www.kteller.com/store/index.php/cPath/26
5 Bolt Downpipe Flange: http://www.kteller.com/store/p...d/701
Modified by KTeller8 at 1:44 PM 3/23/2005
Old May 23, 2004 | 07:28 PM
DSC's Avatar
DSC
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (KTeller8)
Awesome seller!
*edit*Will most deffinetely be picking a system up very soon.
Old May 23, 2004 | 07:59 PM
Kutsuju_SLeePER's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (DSC)
Awesome Seller
Old May 23, 2004 | 09:24 PM
FredoSP's Avatar
I have to take pictures of my 3" from Kteller,
Sounds great also!!!!
Great Seller
Old May 24, 2004 | 10:28 AM
95gsrturbo's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (FredoSP)
are you offereing a group buy???
also - something i noticed - on your "SLIP FIT KIT" does this mean i dont have to weld?? i would think its only a temp solution to fit until i get to an exhaust shop and have them weld it up for me right??
by the way site seems down
thanks
Old May 24, 2004 | 11:46 AM
KTeller8's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (95gsrturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrturbo &raquo;</TD></TR><TR><TD CLASS="quote">are you offereing a group buy???
also - something i noticed - on your "SLIP FIT KIT" does this mean i dont have to weld?? i would think its only a temp solution to fit until i get to an exhaust shop and have them weld it up for me right?? </TD></TR></TABLE>
on the bolt up system, if you click the pictures. you ll see how it slips into each other bout 2-3" wide.. well snug and secure enough to not need them welded: it wont move once the hangers are in place and installed..
if your looking at the slip fit/weld kit then you can use the slips just the same but need the flange and hangers weled.. if you decide not to use teh slip joints.. then you must cut them off, or the system will not fit properly and could be to long..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
thanks </TD></TR></TABLE>
i just noticed that, and am looking into that..
you can click pictures to get to the item. something with the side bar is messed up..
if not you can send any orders to me:
sales@kteller.com! or pm , ill take care of ya.
Old May 24, 2004 | 04:32 PM
95gsrturbo's Avatar
never mind i just realized there are two separate systems, one you offer is bolt up and slip fit - the other is weld together for a bit cheaper--
the only problem is you do not offer the slip fit in 3" -- any plans in the making?
so are you gonna offer a group deal to HT members again any time soon?
and how much off?
Old May 24, 2004 | 04:40 PM
ek_david's Avatar
bump for this great seller!
Old May 24, 2004 | 08:31 PM
hatinginda772's Avatar
I am looking for one of these for a CRX
Old May 24, 2004 | 08:59 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrturbo &raquo;</TD></TR><TR><TD CLASS="quote">never mind i just realized there are two separate systems, one you offer is bolt up and slip fit - the other is weld together for a bit cheaper--
and how much off?</TD></TR></TABLE>
there are two seperate systems:
one is bolt up and other is slip/weld.. it slips together but you have to weld the hangers and flanges on~ yes that one is cheaper and only one available in 3".
the link in the top of this thread has the link to the 3" slip/weld kits... just use the pull down tabs
Old May 24, 2004 | 09:00 PM
KTeller8's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (hatinginda772)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatinginda772 &raquo;</TD></TR><TR><TD CLASS="quote">I am looking for one of these for a CRX</TD></TR></TABLE>
its there, click the link up above in the first thread.. and go to crx, pick mild or stainless, pick either 2.25-2.5-3".. easy as that
Old May 25, 2004 | 11:51 AM
ExplicitSpeed's Avatar
So $215 shipped for 3" mandrel bent piping stainless steel for crx 88-91? flange also for DP?
Old May 25, 2004 | 02:02 PM
KTeller8's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (ExplicitSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed &raquo;</TD></TR><TR><TD CLASS="quote"> flange also for DP? </TD></TR></TABLE>
what kind of flange you need, i got 5 t3 or t3/t4 five bolt flanges here left..
Old May 26, 2004 | 07:23 AM
vti2's Avatar
Im me for the price off a 3" exhaust sistem for a EG9 sedan Sir.
Old May 26, 2004 | 08:00 PM
KTeller8's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (vti2)
got PM sir
remember we offer both mild and stainless versions!
Old May 27, 2004 | 11:14 AM
quik sol's Avatar
I am gonna be getting some U bends from ya :D gimme a day or 2 to figure out how many I need
Old May 28, 2004 | 05:34 AM
KTeller8's Avatar
cool, look up top, i added some more items.. i am trying to help you guys from having to always look around for parts
Old May 29, 2004 | 09:55 PM
pissedoffsol's Avatar
25 Year Member
Default Re: (KTeller8)
bump for mike
bought mine a year ago or so... jsut got it on. lol
was a hair long in a couple parts, but the bends were perfect
Old May 30, 2004 | 09:45 AM
quik sol's Avatar
Default Re: (pissedoffsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">bump for mike
was a hair long in a couple parts, but the bends were perfect </TD></TR></TABLE>
wow, guess with as many as he was making theres going to MAYBE be 1-2 off....Mine fit better than any bolt on catback I have ever used.....KTeller has my bussiness for life...and I will never buy a catback again.
Also recommend em alot too
Old May 30, 2004 | 11:46 AM
quik sol's Avatar
Kteller, I emailed ya. Get back to me ASAP so I can send the payment on monday :D
Old Jun 1, 2004 | 02:50 PM
hyperintegra's Avatar
you gona have a group buy?
Old Jun 3, 2004 | 04:00 PM
Boosted Chemist's Avatar
Default Re: Kteller 3" Exhaust Systems and Mandrel Bends (hyperintegra)
bought my I/C piping from him
Old Jun 9, 2004 | 08:12 AM
KTeller8's Avatar
IC piping, Downpipes, and all other FI materials available
Old Jun 11, 2004 | 10:31 AM
KTeller8's Avatar
Would anyone be interested in Direct Bolt Up 3" kits?
if so, let me know what year and model car.
Old Jun 13, 2004 | 05:18 PM
t04ecvc's Avatar
I got my downpipe materials from Kteller
