Car cranks but won't start over? WTF?
Old May 23, 2004 | 01:21 PM
trooper0641's Avatar
Default Car cranks but won't start over? WTF?
Car was working fine yesterday, this morning i started up...it starts up...went back inside the house...5 mins later...i came out and my car was dead. I try to start it...it cranks but no spark. So im thinking it has to be the distributor, luckily...i had a spare distributor on me. I changed the distributor, and still the same problem..."crank but not turning over". So I was thinking "maybe" its the gas...because my "gas meter doesnt work" and i have been driving hard lately. So i filled it up with 2 gallons...and still the same problem. Anybody have any ideas?
Old May 23, 2004 | 01:39 PM
0ptimus prime's Avatar
Default Re: Car cranks but won't start over? WTF? (trooper0641)
check to see if your fuel pump is priming, and check the fuel pressure. If you made sure you have a spark coming from both the distributors, it should be fuel related. Maybe you clogged the fuel filter by letting the car run out of gas? I'd check all of the fuel components next.
Old May 23, 2004 | 04:16 PM
Default Re: Car cranks but won't start over? WTF? (0ptimus Prime)
ttt will do, anybody else?
Old May 23, 2004 | 04:23 PM
Uncle Ben's Avatar
I feel your pain...my z6 is doing the same thing....EXCEPT, if I wait for about a minute, it WILL start. My pump is kicking, so I'm going to check the fuel filter tomorrow. Are you sure it's a spark problem and not primarily a fuel thing??
Old May 23, 2004 | 04:29 PM
Default Re: Car cranks but won't start over? WTF? (Uncle Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Uncle Ben &raquo;</TD></TR><TR><TD CLASS="quote">I feel your pain...my z6 is doing the same thing....EXCEPT, if I wait for about a minute, it WILL start. My pump is kicking, so I'm going to check the fuel filter tomorrow. Are you sure it's a spark problem and not primarily a fuel thing??</TD></TR></TABLE>
im pretty sure i have a fuel problem now...because in the past i went through 3 distributors...but this time its different. I can hear the spark plugs sparking..."eerr...err...err..tack" but there is no fuel going through? How do i check the fuel filter? What should i look for?
Old May 23, 2004 | 04:34 PM
Uncle Ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">How do i check the fuel filter? What should i look for?</TD></TR></TABLE>
I believe it's against the firewall. Look for a canister type container with two hoses running to it. I never had this type of problem before either, but i'm sure if it's bad you will see a build-up of some kind. Maybe someone would be kind enough to provide us a pic? It's kind of hard to explain without one. Good luck man
Old May 23, 2004 | 05:23 PM
thanks i know what it looks like...i just switched out mines with a brand new one about 5 months ago.
ttt fuel problem...dont know whats going on...nor do i know what to look for.
Old May 23, 2004 | 05:35 PM
is it bad to run out of gas?
Old May 23, 2004 | 05:49 PM
Old May 23, 2004 | 06:22 PM
help me someone this is not a everyday situation!
Old May 23, 2004 | 06:58 PM
32rwfedasde
Old May 23, 2004 | 09:53 PM
JDMlyfestyle's Avatar
if ur not gettin any spark. i would have to say check your grounds. i had the thermostat ground vibrate loose and it wouldnt allow me to start my car. tightend the bolt and she fired right up.
Old May 24, 2004 | 06:38 AM
Default Re: (JDMlifestyle)
O i have spark alright, i try to start it up this morning and it sounded like it was going to start but lacking fuel? how could this be?
Old May 24, 2004 | 06:47 AM
JDMvtecDRAGSTA's Avatar
have u tried to push start it?
if u push start it and it works, it could either be ur starter, or ur battery sucks already and its time for a replacement
Old May 24, 2004 | 07:19 AM
fathergoose's Avatar
I can see two thing, can you hear your fuel pump priming? if not, try to change the main relay, if itdoesnt help, it's the fuel pump. You also have a fuse for the fuel injection, you should look at that
Old May 24, 2004 | 07:36 AM
Default Re: Car cranks but won't start over? WTF? (JDMvtecDRAGSTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMvtecDRAGSTA &raquo;</TD></TR><TR><TD CLASS="quote">have u tried to push start it?
if u push start it and it works, it could either be ur starter, or ur battery sucks already and its time for a replacement</TD></TR></TABLE>
yes ive tried that.
Old May 24, 2004 | 07:37 AM
Default Re: (fathergoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fathergoose &raquo;</TD></TR><TR><TD CLASS="quote">I can see two thing, can you hear your fuel pump priming? if not, try to change the main relay, if itdoesnt help, it's the fuel pump. You also have a fuse for the fuel injection, you should look at that</TD></TR></TABLE>
main relay is only when your car dies when its temperate...meaning hot or cold. fuses are good.
Old May 24, 2004 | 07:38 AM
ABK's Avatar
ABK
Listen if your fuel pump is priming. When you run out of gas, fuel pump goes dry and might blow.
Old May 24, 2004 | 08:03 AM
Default Re: Car cranks but won't start over? WTF? (ABK)
priming? when i start my car...it cranks wont turn over...and i just noticed a second sound...like "woah woah woah woah"...could that "woah" sound be priming?
Old May 24, 2004 | 08:19 AM
ttt sounds weird...
Old May 24, 2004 | 08:31 AM
t25hatch's Avatar
the car doesn't need to be on to hear the pump priming, turn your car to the ON position, don't try to start it. once its at the on position, you should hear the fuel pump, its located under the back seats on the right hand side (right hand side as if you were sitting in the car).
Old May 24, 2004 | 08:52 AM
Default Re: Car cranks but won't start over? WTF? (t25hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t25hatch &raquo;</TD></TR><TR><TD CLASS="quote">the car doesn't need to be on to hear the pump priming, turn your car to the ON position, don't try to start it. once its at the on position, you should hear the fuel pump, its located under the back seats on the right hand side (right hand side as if you were sitting in the car).</TD></TR></TABLE>
the fuel pump is located in under the back rear seats? what the hell i always thought it was in the engine bay somewhere. anyways, i tried to do what you did...turned the car to the ON position...no sound coming from anywhere what so ever. Is it possible to have a clogged up fuel filter?
Old May 24, 2004 | 09:05 AM
ttt help me
Old May 24, 2004 | 09:40 AM
23dszasfd
