what are these hoses by speedo cable on a b18 for?
Old May 23, 2004 | 01:04 PM
lococoin's Avatar
Default what are these hoses by speedo cable on a b18 for?
we are trying to figure out where these go as we are doing a swap into an ef civic.
any ideas
Old May 23, 2004 | 01:10 PM
EL Vap133's Avatar
Default Re: what are these hoses by speedo cable on a b18 for? (lococoin)
Which ones? The ones on the tranny? If so, just loop them, you have no use for them. They are used for power steering in Japan.
Old May 23, 2004 | 04:06 PM
0554's Avatar
it is for your power steering. it slows the fluid down at high speeds so it will basically harden your steering at high speeds . someone please correct me if i am wrong.
Old May 23, 2004 | 06:26 PM
lococoin's Avatar
Default Re: (88crex)
ok thanks
Old May 23, 2004 | 08:13 PM
FULL-RACE EP3's Avatar
Default Re: (lococoin)
your avatar is scary!!!
Old May 23, 2004 | 08:21 PM
X-Static's Avatar
take out the whole assembly and use your OEM EF speedo cable...use the lil bracket that came off your d-series to keep the EF cable in place
Old May 23, 2004 | 09:00 PM
5litereater's Avatar
Default Re: (Pooptooth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pooptooth &raquo;</TD></TR><TR><TD CLASS="quote">your avatar is scary!!!</TD></TR></TABLE>
seriously, wtf is that?
Old May 24, 2004 | 01:29 AM
lococoin's Avatar
Default Re: (5litereater)
its my kid, whats wrong with him
Old May 24, 2004 | 05:41 AM
91civicDXdude's Avatar
speed sensitive power steering.
Old May 24, 2004 | 08:11 AM
EFSiR's Avatar
hey, That's hydro trany.
Old May 24, 2004 | 08:47 AM
4drEF's Avatar
Keyboard Humorist
Default Re: what are these hoses by speedo cable on a b18 for? (X-Static)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X-Static &raquo;</TD></TR><TR><TD CLASS="quote">take out the whole assembly and use your OEM EF speedo cable...use the lil bracket that came off your d-series to keep the EF cable in place</TD></TR></TABLE>
Am I reading that right?
Can this assembly be installed on a USDM car?
I have PS on my car... it might be nicer if it wouldn't be as active at freeeway speeds.
Old May 24, 2004 | 09:26 AM
X-Static's Avatar
Default Re: what are these hoses by speedo cable on a b18 for? (4drEF)
well im recomending this to this guy cause he dont have power steering
for you if you could find the assembly then it probably could be installed on your car, i know i installed my USDM assembly on a JDM motor (power steering equiped) but my crx dotn have power steering so i took out the jdm speedo cable assembly and used my USDM...so if i could switch them, i dont see why you cant do the opposite
Old May 24, 2004 | 11:19 AM
BLT2FLY's Avatar
You could also simply loop them together as one.
Old May 24, 2004 | 11:43 AM
APEX CRX's Avatar
Default Re: what are these hoses by speedo cable on a b18 for? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Which ones? The ones on the tranny? If so, just loop them, you have no use for them. They are used for power steering in Japan. </TD></TR></TABLE>
yup, when I saw that on my JDM cable tranny I was like wtf too.
Old May 24, 2004 | 11:47 AM
lococoin's Avatar
Default Re: what are these hoses by speedo cable on a b18 for? (EFSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">hey, That's hydro trany.</TD></TR></TABLE>
No its a cable tranny from a 93 integra.
Old May 24, 2004 | 11:53 AM
EL Vap133's Avatar
Default Re: what are these hoses by speedo cable on a b18 for? (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
yup, when I saw that on my JDM cable tranny I was like wtf too.</TD></TR></TABLE>
lol, I'm sure everybody thought the same thing.
tortega104
Nov 5, 2009 11:02 AM
jllong95
Transmission & Drivetrain
Oct 20, 2009 08:29 PM
honda06si
Aug 8, 2004 07:25 PM
Black R
Jun 2, 2004 11:21 PM
lococoin
May 23, 2004 06:27 PM
