What kind of clutch fluid are you using?
Old Nov 8, 2001 | 10:04 AM
mugen22's Avatar
Default What kind of clutch fluid are you using?
After almost two full days of hard running at the track, my car suffered it's first "hick-up" of sorts in the two years I've had it. Coming out of turn 1 at GingerMan Raceway, my car would not shift down to second or third or any gear. So I pulled off into the grass and stopped the car, let the clutch out, pushed it back in and then magic. All of the gears were back. This came with no warning, grinding and this is the first time it has happened.
So I ask you guys/gals, what clutch fluid are you using? I'm pretty sure that mine boiled, so I am considering using something with a higher boiling point. Thanks for your help.
Old Nov 8, 2001 | 10:17 AM
976's Avatar
976
New User
Default Re: What kind of clutch fluid are you using? (mugen22)
Currently I am using STP DOT 3, but I want to switch to ATE superblue. I can't find anywhere to order it.
Old Nov 8, 2001 | 10:29 AM
Gabe's Avatar
I'm using AP Racing 551 Racing fluid. Any high-performance DOT 3 fluid (or any DOT 3 fluid for that matter) will work. I noticed a little firmer pedal when I switched, but then again my fluid was black as night when I changed it.
BTW you can get ATE fluid from www.daliracing.com.
Gabe
[Modified by Gabe, 1:30 PM 11/8/2001]
Old Nov 8, 2001 | 10:33 AM
Honda318dx's Avatar
Default Re: What kind of clutch fluid are you using? (Gabe)
ATE Superblue/ATE Type 200 Same fluid, just one is blue and the other is gold..
Old Nov 8, 2001 | 10:35 AM
Honda318dx's Avatar
I Highly doubt you boiled the clutch fluid.. Sounds like the clutch MC is starting to go.. =~(
Old Nov 8, 2001 | 01:22 PM
mugen22's Avatar
Default Re: What kind of clutch fluid are you using? (Honda318dx)
Damn I hope not. I guess that is why I have the extended warranty though. I may not have boiled it, but it does not look so good. The other thing I want to check into is the slave cylinder, but I'll start with the easy things first. Thanks for all of your replies.
Honda318dx, are you going to try and make it out to Laguna Seca for the SpeedTrial event?
Old Nov 8, 2001 | 01:31 PM
Honda318dx's Avatar
So far, Jon Felton and I plan on going.. Are you?? We are gonna try to rent the baddest car we can find =~)
Old Nov 8, 2001 | 01:56 PM
mugen22's Avatar
I am trying to go as well. We are also looking to rent something exotic. Maybe a Focus!!!
So have you had problems with your transmission, or clutch etc? It was really wierd because this happened to my friend one lap later. The exact same thing. Unfortunately, he went back out and started goofing off and that is why we are going back to the track this weekend with a trailer. Ouch.
Old Nov 8, 2001 | 02:16 PM
Honda318dx's Avatar
My tranny has been fine, just take it easy on it.. They are fragile.. Have you ever experience HI RPM cutoff? Mainly on left hand corners.. Both my motors have/do do it.. A friend in a SH prelude was having the same problem with the same corners..
Old Nov 8, 2001 | 02:44 PM
976's Avatar
976
New User
Haha
[Modified by B21A, 11:44 PM 11/8/2001]
Old Nov 9, 2001 | 09:14 AM
mugen22's Avatar
Corey, I have never experienced engine cut-out. GingerMan has a long fast left sweeper that I am usually right at redline in third gear (about 90mph in a 98) coming out of and I have never had that happen. Did the motor just quit for a second or did it blow? I guess I should knock on some wood.
My tranny has been flawless up to this point and it really feels as though it is a clutch problem relating to the master cylinder, clutch fork, slave cylinder or even just air in the line. I am going to bleed the clutch line and see if that helps and if it doesn't (which I figure) then it will either go up to King or to my Honda dealer.
superhypie
Aug 30, 2008 05:56 PM
TylerC161
Jun 15, 2007 04:58 PM
lude98SH
May 20, 2006 12:30 PM
B18Redline
Aug 18, 2003 10:56 AM
KF_S2000
Jul 21, 2002 01:41 PM
