weird niose from rear passanger side when i corner hard
Old May 22, 2004 | 04:57 PM
BlackCRX's Avatar
Default weird niose from rear passanger side when i corner hard
when i corner left hard i hear a kind of metal on metal clunking niose from the back passanger side
any idea;s ??
Old May 22, 2004 | 05:06 PM
HamiltonRex's Avatar
Default Re: weird niose from rear passanger side when i corner hard (BlackCRX)
Suspention sounds tired. I suggest you give it a visual inspection. Check for loose parts, warn bushings, Etc.
-Eric
Old May 22, 2004 | 05:11 PM
BlackCRX's Avatar
Default Re: weird niose from rear passanger side when i corner hard (HamiltonRex)
currently im on h&r race with agx springs
when they were put in i had new bushings installed
im kinda thinking it might be the sway bar bushing but the sound is more metal like
Old May 22, 2004 | 06:41 PM
Boosted Chemist's Avatar
if your rear trailing arm bushing is fucked it will sound liek a clunking noise, 30 bucks later with es busing and that is fixed
Old May 22, 2004 | 06:53 PM
Sikocivic's Avatar
Check the rear struts. Mine hit the lower control arms a little when I corner hard to the left. They are rubbing on the spring mount part of the strut.
Old May 23, 2004 | 10:40 AM
BlackCRX's Avatar
anymore ideas ??
Oakmanx
Suspension & Brakes
Jun 20, 2006 07:16 AM
yh23
10
May 31, 2005 05:11 PM
92integraVTECgsr
Feb 18, 2005 01:02 PM
lOOkatme
Apr 8, 2004 07:13 AM
ITR#JohnBasedow
Aug 24, 2002 12:47 PM
