code 16
Old May 22, 2004 | 04:46 PM
sitrucjr's Avatar
Default code 16
i have a stock d15b2 and today i was driving and the car started idling weird then all of a sudden died. started it back up then i noticed everytime i took it over 3000 rpm it would start bogging then it died and would not start. checked the codes and got a code 16, but like for the past week my distributor has been making a low pitch sqeal so i had an extra distro handy and changed it out when it died and the car started up no problem, i know code 16 is the injectors but what i wanted to know was could bad injectors make my dizzy go out or what do you guys think?
Old May 22, 2004 | 06:24 PM
91civicEX's Avatar
Default Re: code 16 (sitrucjr)
maybe it was code 15 which is ignitor. if a dpfi car throws a code 16 and still drives it is most likely the fuel pump. if one of the injectors stops working then the engine dies.
Old May 22, 2004 | 06:52 PM
sitrucjr's Avatar
Default Re: code 16 (91civicLX)
you think having the distro too retarded or too advanced could have caused the distro to go out?
Old May 22, 2004 | 10:47 PM
90JPRCRX's Avatar
Smells like Tuna
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">maybe it was code 15 which is ignitor. if a dpfi car throws a code 16 and still drives it is most likely the fuel pump. if one of the injectors stops working then the engine dies.</TD></TR></TABLE>
this is true
my car is throwing 16 almost every day if not twice a day now
when i start it up it putters a bit till i go then its fine
Metal Head
Sep 1, 2008 08:12 AM
bgcrx
Feb 21, 2008 07:24 PM
SupraRXZ
Apr 6, 2006 09:48 AM
brbHPR
Jun 15, 2003 05:25 PM
SLIMJIMsi97
May 2, 2003 11:06 PM
