Help with swap....D16Z6
Old May 22, 2004 | 03:38 PM
Broken Gearbox's Avatar
Default Help with swap....D16Z6
Modified by Broken Gearbox at 1:19 AM 8/5/2008
Old May 22, 2004 | 04:48 PM
Default Re: Help with swap....D16Z6 (2.2L)
anyone know?
Old May 22, 2004 | 07:23 PM
hotintegranights's Avatar
im 100% positive code 10,21 will not prevent the car from cranking over,not sure on code 19. but look also look for little things sometimes the smallest wire unplug can cause you weeks of downtime, check your ground wires, on my last swap i 4got to plug in the ground wire for the tranny and spent the whole day trying to figure out y it dint crank over, so check everything 2x,3x over. also make sure all spark plug wires are plugged in the right order.
Old May 22, 2004 | 07:41 PM
Default Re: Help with swap....D16Z6 (hotintegranights)
well we used a Manual Ecu from the stock motor (d15b8) to see if it would start...and it did...and the only CEL was 10 intake air temperature sensor...of course the vtec spool didnt show because the ecu doesnt have vtec. but the car still started...not driveable though idle really high.
Old May 22, 2004 | 07:57 PM
Scean's Avatar
yea you definatly need a 5spd ecu, and after that you may still need some trouble shooting on that 10 cel but it should be drivable and have vtec once u get the correct ecu, p28 by the way good luck
Old May 22, 2004 | 08:08 PM
Default Re: Help with swap....D16Z6 (blackcivic95)
really...so code 19 is keeping the motor from not starting?
Old May 22, 2004 | 09:09 PM
articbluedc5's Avatar
I just threw a code 10 and the 21, car started fine. I just got a new IAT sensor and vtec hooked up. I have an extra IAT which is causing your 10 I got 3 of them from the junk yard. Hit me up if you want one
Old May 22, 2004 | 10:01 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2L &raquo;</TD></TR><TR><TD CLASS="quote">really...so code 19 is keeping the motor from not starting?</TD></TR></TABLE>
Well from what I understand code 19 means your torque converter clutch is locked so it wont allow you to start since if the converter was locked then the car will lundge forward when you start it up.. So it make sense that it will not turn over
Old May 22, 2004 | 10:04 PM
ABK's Avatar
ABK
Default Re: Help with swap....D16Z6 (BatuKing)
it should start, anyways but have a crappy idle. You can chip it search.
Unphzd
75
Dec 16, 2010 08:27 AM
Metal Head
Sep 15, 2006 02:35 PM
b18c4dr
Mar 1, 2006 03:09 PM
c8r9x
Aug 9, 2003 12:16 PM
93EH6
Jan 30, 2003 09:11 PM
