Nice info about ITR
Old Nov 8, 2001 | 07:15 AM
Mike K's Avatar
Default Nice info about ITR
Well, I figured if anyone on the internet would appreciate this, it would be the H-T ITR board..
I got a nice 10page booklet on the Integra and it's differences, etc. Specifics not normally published, blah blah.. basically for AHM employees.
Since you guys seemed to like my little OEM Coolant "lesson", you will enjoy this one as well....
I just picked up the interesting tid-bits of this 10 page booklet on Integras...
"The Type R's front suspension uses coil-over gas-pressurized damper assemblies fitted with Honda Progressive Valve (HPV) unit for progressive damping action. The spring and damping rates have been greatly increased relative to the other Integra models in order to improve handling on the road course. Front spring rate has been increased 22% with a 115% increase in compression damping, and a 70% increase in rebound damping. Additionally, the damper mounting bushing stiffness has been increased five-fold.
Damping rates for the Type R's rear suspension have also been increased with compression damping settings in the progressive valve unit up by 66%, and rebound damping increased 31%. The diameter of the rear stabilizer bar has been greatly increased from 13mm to 22mm to reduce body roll. To enhance rear wheel stability, the bearing span within the rear wheel hub has been increased by 10mm. All these special improvementsn and calibrations ensure that your Type R clients will find that the car exceeds their demanding expectations for suspension performance.
The Type R, with its larger brakes(front: up from 262mm to 282mm; rear: up from 239mm to 260mm) and larger calipers, also uses a refined ABS system which is 12.3 lbs. lighter than the standard Integra system. The weight savings helps the Type R accelerate, turn and stop better. The brakes themselves offer additional power and fade resistance for spirited driving and racetrack use.
Upholstery material has been chosen for its appearance, durability and grip-an importatn factor in a vehicle with the cornering power of Integra. The Type R's exclusive fabric upholstery scheme offers a rac-oriented feel and high traction with a center portion that works to hold the driver in place while providing excellent breathability.
The close ratio transmission used in the Type R features different ratios, bearing design and clutch than that of the GSR. With the phenomenal high-rpm performance of this engine, these changes add strength and provide close-ratio staging to take full advantage of the added power. For improved throttle response, the Type R uses a special lightweight flywheel coupled with a heavy duty clutch. The Type R also has a uniquely integrated aluminum die-cast engine stiffener for improved engine-to-transmission fastening rigidity in order to cope with additional engine output and high rpm operation. With this arrangement, vibration is reduced 22%, compared to the traditional separate fore and aft fastening systems.
The crisp manual transmission shifting action that your clients will notice in all Integra models is yet another contributing factor that helps make them such entertaining, driver-oriented cars.
Honda kicks ***.
Old Nov 8, 2001 | 07:19 AM
skafia's Avatar
25 Year Member
Default Re: Nice info about ITR (Mike K)
yeah!
Old Nov 8, 2001 | 07:21 AM
BlueR's Avatar
More, More
Flux's Avatar
Default Re: Nice info about ITR (skafia)
Awesome
I'm saving that post...
Old Nov 8, 2001 | 07:30 AM
kenji's Avatar
25 Year Member
Default Re: Nice info about ITR (Flux)
I have a copy of the 1997 Acura Integra Type-R 'fact booklet' from my local Acura service department.
If I ever get time I will scan it and post it.
Lots of good info to dispell all myths.
-kenji
Old Nov 8, 2001 | 07:48 AM
miketegra's Avatar
Mike K - can you post the link to the coolant lesson?
Old Nov 8, 2001 | 08:40 AM
 The Snipe-R's Avatar
New User
Good job. Keep it handy so that you can cut and paste whenever you see a post about the R being just a glorified GSR.
Old Nov 8, 2001 | 08:44 AM
sackdz's Avatar
Default Re: Nice info about ITR (Super*)
Everyone- do remember to quote that bulletin the next timer you're denied warranty because you raced your car. Read it, it specifically says improvements were made to the type r to increase it's performance on a road course
Old Nov 8, 2001 | 08:55 AM
itr1275's Avatar
Default Re: Nice info about ITR (kenji)
Ditto, got it from my buddy that was an Acura Tech at the time. I also have the '97 dealer poster.
Old Nov 8, 2001 | 10:10 AM
mr2's Avatar
mr2
Default Re: Nice info about ITR (itr1275)
lol sweet post
Old Nov 8, 2001 | 10:24 AM
Mike K's Avatar
Default Re: Nice info about ITR (miketegra)
here ya go..
https://honda-tech.com/zerothread?id=83344
Old Nov 8, 2001 | 10:31 AM
nsxtcjr's Avatar
New User
The coolant info can also be found in the NSX FAQ.
[Modified by nsxtcjr, 1:31 PM 11/8/2001]
Old Nov 8, 2001 | 10:42 AM
Mike K's Avatar
Default Re: Nice info about ITR (nsxtcjr)
Now THAT'S the complete bulletin.
My fingers got too tired of typing and I only picked the best info when I posted my coolant post.
Old Nov 8, 2001 | 11:49 AM
mugenr#1011's Avatar
very nice, make's me wanna go drive right now...good post
Old Nov 8, 2001 | 12:09 PM
Black R's Avatar
25 Year Member
.....damn that was a lot to type.
Any chance of scanning that one in?
Old Nov 8, 2001 | 12:17 PM
itrsport.com's Avatar
Default Re: Nice info about ITR (Black R)
For those of you who would like to read more good stuff with pictures check out the technical page on my site.
http://members.aol.com/josh3030/tech.html
Old Nov 8, 2001 | 01:32 PM
Rain_man's Avatar
New User
Default Re: Nice info about ITR (itrsport.com)
What's this about the tranny/engine stiffener?
vinuneuro
Suspension & Brakes
Oct 19, 2007 01:52 PM
kadeem71
Jan 31, 2007 09:32 AM
mstewar
11
Aug 21, 2004 06:12 AM
HondaJon
Dec 9, 2001 05:42 PM
