Solutions to rubbing rear suspension
Old May 21, 2004 | 10:16 PM
rossockr's Avatar
Default Solutions to rubbing rear suspension
My brother has a 2000 v6 coupe
His set up is as follows....
Eibach Pro-kit Springs and Eibach Sway bars
Tokico HP Blues
17X7 Enkei's with a 40 offset
215/50's
The problem is only when hitting a fairly serious bump the rear tires rub. Other than that it handles like a charm.
For a while he was running with spring spacers in as a temporary ghetto solution, but I was thinking....
Would adjustable shocks do the trick?
I've read about rolling the fenders, it doesn't even sound good, but what all does it entail? We would like to avoid simply cutting a whole or space out to prevent the rubbing, we'd like to keep the body in tact. What are some long term solutions?
TIA
Old May 22, 2004 | 07:30 AM
Kavehman's Avatar
Default Re: Solutions to rubbing rear suspension (rossockr)
do you know wgere exactly its rubbing ?cause i have a 6th gen and am running 225/40/18, 40 offset on Hr sports, and mine only rubs when i hita big dip with 2 people in the back.
Try to find out where its rubing and go from their..
Old May 22, 2004 | 10:36 AM
jwogen1's Avatar
i would say avoid big bumps
Old May 22, 2004 | 06:00 PM
FatJoe's Avatar
Default Re: Solutions to rubbing rear suspension (jwogen1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 &raquo;</TD></TR><TR><TD CLASS="quote">i would say avoid big bumps </TD></TR></TABLE>
right on
more than likely adjustable shocks will help with this problem, but it might not. the rubbing shouldnt be all that much of a problem to you unless you really hate it for that 1 second that it rubs over occasional big bumps. if you dont have aftermarket shocks to begin with, you should get some
Old May 22, 2004 | 07:57 PM
secksiman19's Avatar
Default Re: Solutions to rubbing rear suspension (FatJoe)
whats the drop with your prokits? adjustable shocks are always a grand idea when lowering your car a noticable amount(1.5+??). you might want to get them anyway since you will want them in the future and see if it helps
Old May 22, 2004 | 07:58 PM
Default Re: Solutions to rubbing rear suspension (secksiman19)
and wth is up with your avatar!?
Old May 22, 2004 | 08:03 PM
fw190bvi's Avatar
prokits are roughly 1.3" drop, and were designed to be able to work well with OEM shocks....though adjustables will make a world of difference.....
for the avatar, thats just a woman with 2 HUGE *** goiters on her neck......common problem in 3rd world countries, created by a lack of iodine in the diet (hence why most table salt is <U>iodi</U>zed)
Old May 22, 2004 | 09:12 PM
iam7head's Avatar
Default Re: Solutions to rubbing rear suspension (fw190bvi)
prokit for accord is 1.5 inch drop
I was on prokit with the 17x7, with TLS swaybar and it's not even close to touching anything.
then i drop my pos with h&R race, it still would rub.
it got to be something
Old May 23, 2004 | 05:14 PM
rossockr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatJoe &raquo;</TD></TR><TR><TD CLASS="quote">
if you dont have aftermarket shocks to begin with, you should get some </TD></TR></TABLE>
He has tokico HP Blue Shocks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kavehman &raquo;</TD></TR><TR><TD CLASS="quote">do you know wgere exactly its rubbing ?</TD></TR></TABLE>
It's definitely in the back, mostly on the passenger side, some on drivers side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by secksiman19 &raquo;</TD></TR><TR><TD CLASS="quote">and wth is up with your avatar!? </TD></TR></TABLE>
That's Goiter girl, fw190bvi, was perfectly correct with the definition. I like it cause it looks like she's got a large black ball sac dangling from her neck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">prokit for accord is 1.5 inch drop
it got to be something</TD></TR></TABLE>
What shocks were you running with?
and when you say it still would rub do you mean wouldn't?
Thanks for the feedback guys.
Now say if I were to go for the adj. shocks should I just get the rear or do them all around for the best compatible set up despite costs?
rugimpy
Suspension & Brakes
May 15, 2009 05:06 PM
camelian
Suspension & Brakes
Dec 11, 2007 02:53 PM
01blackgsr
Jul 31, 2005 05:55 PM
DC4RS Integra
Apr 27, 2005 10:40 PM
R-Toyz.com
Feb 19, 2003 12:45 PM
