::installing a rear sway bar with stock EG LCAs???
Old May 21, 2004 | 10:02 PM
spock_rocker's Avatar
memoryFAB.com representative
Default ::installing a rear sway bar with stock EG LCAs???
i dont know if i should just drill into the LCAs or if i should try to find a set of like GSR lcas, or look into SRR, but im trying to be as frugle as i can. thanxx
Old May 21, 2004 | 10:39 PM
Nerologic's Avatar
stock gsr LCA is ur best bet aftermarket is too expensive and drilling sucks ***
Old May 21, 2004 | 11:13 PM
Jonny G.'s Avatar
Default Re: ::installing a rear sway bar with stock EG LCAs??? (spock_rocker)
I use Integra LCAs with my ITR rear sway bar and they work perfect. I think mine actually came off an LS cause there was no sway bar on it to begin with, just the holes where the endlinks bolt up to.
They are definitely a cheaper alternative to buying aftermarket ones, got mine from a junkyard for $50
Old May 22, 2004 | 12:28 AM
Sector9guy's Avatar
Default Re: ::installing a rear sway bar with stock EG LCAs??? (Jonny G.)
all 94up tegs have stock rear sway bars. just different diameters for different models.
Old May 22, 2004 | 07:36 AM
Default Re: ::installing a rear sway bar with stock EG LCAs??? (sector9guy)
i have an SRR sway bar, isn't it 94-01 integra stuff fits EGs??
Old May 22, 2004 | 02:46 PM
what is the strength of the LCAs once youve drilled holes? i just want to be sure they are ok for autoX and what not.
Old May 23, 2004 | 06:32 AM
anyone??
Old May 23, 2004 | 06:43 AM
IS3Fifty's Avatar
Personally, I would line the sway bar up under the car as if you are mounting it. Find exactly where you will need to drill, then go from there. I mean those LCA's are cast, so they're strong, but structurally depending on where you will need to tap it, I would be a little cautious. SRR LCA's arent that expensive, plus you get that JDM bling! y0!
Jimmy
Suspension & Brakes
Nov 26, 2010 03:09 AM
patrickstar
Mar 1, 2009 09:15 AM
MaaseyRacer
Aug 17, 2004 09:40 PM
Andrew 825SM
Jul 7, 2003 01:19 PM
