how much would you pay for this swap?
From: South LA...107th and fig to be exact...for the foo
b18b bottom end with itr crank,rods,and pistons (o/s)
b16a head ported by Alaniz new supertech flat valves and new bronze guides, Alaniz spring kit with ti retainers, skunk stg 3 cams with str cam gears
itr manifold and t/b
new gaskets and seals used to assemble motor
b16a hydro t/m...perfect condition (no grinds) act clutch (6 puck) and mueller flywheel
hondata s200 with p28 ecu
axles and linkage
as far as horsepower it made 223.4 at Churchs dynapack with no cam tuning
keep in mind that this is a full swap
Modified by myke at 9:08 AM 5/22/2004
axles and linkage
