would a 92 1.5 civic cx tranny work on a 89 si block 1.6
would a 92 1.5 civic cx tranny work on a 89 si block 1.6.
i have a si block with a vtec head i know i gotta run the
vtec harness and ecu, but do i have to change the wire
sistem that goes under the dashboard.
how many hp this sohc vtecs come stock.
It will bolt together and work if you are putting it a 92 and up civic since they have hydro trannys. Anything thats 91 and under is gonna use a cable tranny. If you do have a 91 and uder than you can only use the 92 and up tranny if you get a hydro to cable conversion kit from hasport.
yellowcrx1991
Jan 21, 2003 09:11 PM
