Auto to manual conversions
Hey, I am sure this has been asked a thousand times, but I wasnt able to locate it on the list. So here it goes. What do I need to do to convert a automatic 1995 civic DX to a manual. I have a ecu, tranny, cylinder head, starter, flywheel, and clutch from a 96 civic ex. Would I be able to convert it over to a munual Vtec and if so how?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manko926 »</TD></TR><TR><TD CLASS="quote">Hey, I am sure this has been asked a thousand times, but I wasnt able to locate it on the list. So here it goes. What do I need to do to convert a automatic 1995 civic DX to a manual. I have a ecu, tranny, cylinder head, starter, flywheel, and clutch from a 96 civic ex. Would I be able to convert it over to a munual Vtec and if so how?</TD></TR></TABLE>
- 5spd Pedal Set
- Shift Linkage
- Shifter
- Front Tranny Mount from a 5spd
- Place Racing Upper Tranny Mount
- Clutch Reservior
- Clutch Master Cylinder
- Clutch Lines
- Clutch Slave Cylinder
- 5spd Pedal Set
- Shift Linkage
- Shifter
- Clutch Reservior
- Clutch Lines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef9 »</TD></TR><TR><TD CLASS="quote">what if your doing a manual b series swap into auto d series? do you still need that mount for the tranny?</TD></TR></TABLE>
for 92-95 civics you need the conversion mount, I got mine from jdmshit.com (HCP mount). I've heard that you dont need it 96+ civics, since it the tranny mounts the same way. Good luck.
mini-cRx
Dec 9, 2004 07:26 AM
turismo128
Nov 14, 2002 01:13 PM
threatcon13
Jul 31, 2001 09:04 AM
