How do you install Cold-Air Intake?
Old May 21, 2004 | 05:13 PM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Default How do you install Cold-Air Intake?
What tools would you need to do this? How long does it take?
Old May 21, 2004 | 05:20 PM
RCautoworks's Avatar
Default Re: How do you install Cold-Air Intake? (mario82686)
Screw driver and some sockets. It varies from car to car, I could pull mine out and put it back in with in 5 mins.
Old May 21, 2004 | 05:23 PM
95civicSirCoupe's Avatar
fairly easy. it took me about 8 mins.
but if you want a bypass valve you need to to have something that will cut pipe. like a saw...very fine saw
Old May 21, 2004 | 05:26 PM
GUNNER666's Avatar
Default Re: How do you install Cold-Air Intake? (90blackcrx)
1-unbolt old airbox, from intake manifold. you may have to reove a oxygen sensor
2-bolt new air filter onto tube.
3-bolt onto intake manifold.
-this should take you about half an hour at most and dont forget the tube that gos to the cylinder head
Old May 21, 2004 | 06:00 PM
SOHC4life 96's Avatar
Default Re: How do you install Cold-Air Intake? (GUNNER666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNNER666 &raquo;</TD></TR><TR><TD CLASS="quote">-dont forget the tube that gos to the cylinder head </TD></TR></TABLE>
not to hard of a job, read the instructions if the CAI came with them. probably about 15 mins i'd say
Old May 21, 2004 | 09:05 PM
TwistedSI's Avatar
Instructions with pics: http://www.leftcoastcustoms.com/techcai.htm
Old May 21, 2004 | 09:30 PM
JDMbolo's Avatar
Default Re: (TwistedSI)
Good instructions, that should help who ever needs help
Old May 21, 2004 | 10:40 PM
Dancing is Forbidden's Avatar
Default Re: (HyprEGhb)
we did my friends in a parking lot in savannah after visiting nopi.
Old May 21, 2004 | 11:07 PM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNNER666 &raquo;</TD></TR><TR><TD CLASS="quote">1-unbolt old airbox, from intake manifold. you may have to reove a oxygen sensor
Uh.. why? the O2 sensor is attached to the exhaust mainfold. Unless your talking about the intake temp sensor for OBD-II cars?
Old May 21, 2004 | 11:13 PM
civic_hatchback's Avatar
What about people who dont know how to take off the front bumper?
Old May 22, 2004 | 01:32 AM
CheEsEsTeAk168's Avatar
Default Re: (civic_hatchback)
well on civics, u don't need to take off the front bumper to install it
Old May 22, 2004 | 06:43 AM
Skip01's Avatar
Default Re: (CheEsEsTeAk168)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheEsEsTeAk168 &raquo;</TD></TR><TR><TD CLASS="quote">well on civics, u don't need to take off the front bumper to install it</TD></TR></TABLE>
It would help to take off the bumper but isn't nessasary.You will have to take off the underlining to get the bottom half of the airbox.Its fairly easy though.
Old May 22, 2004 | 08:54 AM
BatuKing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">What about people who dont know how to take off the front bumper?</TD></TR></TABLE>
On a cold air the filter is in the fender / bumper area so its best to remove the bumper it only takes like 10 extra min to remove and re-stall it so why not. It makes the job easier IMHO
Old May 22, 2004 | 09:17 AM
skip.two's Avatar
Default Re: (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">On a cold air the filter is in the fender / bumper area so its best to remove the bumper it only takes like 10 extra min to remove and re-stall it so why not. It makes the job easier IMHO</TD></TR></TABLE>
i just turn my right wheel inward, and put my air filter in through there.
Old May 22, 2004 | 09:26 AM
TwistedSI's Avatar
Default Re: (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">
i just turn my right wheel inward, and put my air filter in through there.</TD></TR></TABLE>
But some of us like to keep our inner fenders. So taking off the front bumper is a must.
Old May 22, 2004 | 09:27 AM
skip.two's Avatar
i did keep my inner fender. i just unscrewed it, placed the filter in, then screwed it back in. its like 4 screws.
Old May 22, 2004 | 09:45 AM
camelian's Avatar
no need to take off the bumper. I think it's a lot easier to just pull off the inner lining, and replace it when you're done. Eitherway will work, I just think taking off the inner lining is easier
Old May 26, 2004 | 05:00 PM
Dc2 Powered's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">Instructions with pics: http://www.leftcoastcustoms.com/techcai.htm</TD></TR></TABLE>
hey bro what kind of intake is that
Old May 26, 2004 | 05:18 PM
00CIVIC-EX-G's Avatar
Default Re: (Speedin Type R)
I have a 2000 Civic EX-G Sedan and when I went to install the cold air I found that the panel that you pass it through to get it to inner bumper was not open. I can see where it is supposed to be knocked out but the metal is all there.
Is this a knockout panel or does it need to be cut
thanks.
Old May 26, 2004 | 05:21 PM
mario82686's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedin Type R &raquo;</TD></TR><TR><TD CLASS="quote">
hey bro what kind of intake is that</TD></TR></TABLE>
Is a AEM cold air intake, the kind that go down by the bumper and the wheel.
Old May 26, 2004 | 06:17 PM
Default Re: (mario82686)
All cold air intakes go down to the wheel, only short ram stays where you can see the filter.
Old May 26, 2004 | 06:43 PM
Dlpz87's Avatar
I used a screw-driver, saw, fingers, and you'll definately need some of those lil rubber screw thingys. I took me about 15mins on my back under my friends car to undo everything with the factory intake box. There is one realllly hard to get to screw right in behind the bumper, so I highly recommend that you do so. After you get rid of that box, (if you haven't removed the bumper) I found it much easier to bring the tube from the bottom up through the hole, as it seems to get stuck from the top.
Old May 28, 2004 | 08:00 PM
Daniel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario82686 &raquo;</TD></TR><TR><TD CLASS="quote">
Is a AEM cold air intake, the kind that go down by the bumper and the wheel.</TD></TR></TABLE>
Actually, that isn't an AEM CAI. If it was, the mounting bracket would be welded to the piping. What that guy has works just as well but is not made by AEM.
Old May 28, 2004 | 11:53 PM
ebay owns hahah.. nice write up by the way.. and i think taking off bumper is easiest to work with because you can see the whole work area.
Old May 29, 2004 | 12:48 AM
bodazappa's Avatar
Most time consuming part is getting the stock air box out, honda feels like they have to bolt that thing down like no other After that 5 min tops.
MR aK
Honda S2000
10
Oct 2, 2008 04:34 AM
SoyMilk
May 5, 2007 04:40 PM
NoRthstaR_
Nov 17, 2006 04:35 PM
jerebear
Aug 26, 2006 10:37 AM
cmck_12
29
Jun 22, 2006 08:40 AM
