Harness Bar Only. Is this possible?
Old May 21, 2004 | 03:59 PM
spyz34's Avatar
Default Harness Bar Only. Is this possible?
Anyone know if a harness only bar exists for 91 crx si. Or can anyone make one.
Old May 21, 2004 | 04:21 PM
cbstd's Avatar
Default Re: Harness Bar Only. Is this possible? (spyz34)
A Porsche 914 harness bar fits a 1st Gen CRX and will probably fit later models.
Contact http://www.pelicanparts.com
Scott
Old May 21, 2004 | 04:50 PM
XrcR6's Avatar
Default Re: Harness Bar Only. Is this possible? (cbstd)
That might work if he had an 88 that has a pillar mounted stock seatbelts like the 1st gen's. But the 91's have the belts mounted to the doors, so he lacks any structurally sound point for a harness bar.
The only thing I've seen traverse the upper-back area of a CRX was something like the EMRacing setup. I believe they were using the hatch strut mounting holes as mounting points. But I wouldn't trust that to hold the driver's upper body weight transferred through the harness.
You'd be better off getting something like an Autopower 4-point roll bar with the harness bar option.
Greg H
Nov 26, 2007 04:39 PM
autoxmyef
Mar 16, 2007 01:10 PM
tdperf
Honda Civic (2006 - 2015)
Jan 15, 2007 08:43 AM
H22A EG6
17
Mar 1, 2004 12:30 PM
garrulous thief
Feb 26, 2004 04:49 PM
