OB2 codes
Old May 21, 2004 | 11:32 AM
scmaguigan's Avatar
Default OB2 codes
I have a 1997 Civic EX and recently my check engine light came on. My mechanic downloaded the code, "P.O. 1259 - VTEC malfunction", but told me that it was undocumented in his manual. The engine seems to be running fine, but I am concerned about driving it until I learn what this code means. I would appreciate any asistance on this matter.
Old May 21, 2004 | 12:40 PM
Frozen E's Avatar
H-T White Ops
look all the way at the top of this page. 2nd post down. It's been stickied for a while.
You're welcome.
Old May 21, 2004 | 02:03 PM
Chiovnidca's Avatar
Default Re: OB2 codes (scmaguigan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scmaguigan &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1997 Civic EX and recently my check engine light came on. My mechanic downloaded the code, "P.O. 1259 - VTEC malfunction</TD></TR></TABLE>
P1259... Have you checked the oil level? Has it been low in the past?
Old May 21, 2004 | 05:24 PM
scmaguigan's Avatar
Default Re: OB2 codes (Chiovnidca)
It was low, but the oil pressure light has not come on. I toppped it off and the check engine light was still on. that's when i went to my mechanic. He said it wasn't oil pressure relaterd, but VTech, that is ignition of fuel injection.
The engine is running smoothly, with no new and strange noises.
Old May 21, 2004 | 05:43 PM
scmaguigan's Avatar
Default Re: (IslandSi)
Thanks for the list, but iut still doesn't tell me what is wrong. Itr could be ignition, fuel injection, valve timing...
But I now know where to look for codes.
Thanks a buncH!
Old May 21, 2004 | 06:33 PM
v4lu3s's Avatar
RTFM
vtec is very dependant on oil pressure as it uses oil pressure ot activate teh cam lobe changeover.
Old May 21, 2004 | 08:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scmaguigan &raquo;</TD></TR><TR><TD CLASS="quote">It was low, but the oil pressure light has not come on. I toppped it off and the check engine light was still on. that's when i went to my mechanic. He said it wasn't oil pressure relaterd, but VTech, that is ignition of fuel injection.
Your mechanic would be wrong about that. The engine being low on oil probably cause the CEL. Try clearing the code, see if it comes back. And keep an eye on your oil level.
Old May 21, 2004 | 08:45 PM
hatchi's Avatar
did you try to reset it when you topped off the oil??
Old May 22, 2004 | 05:21 AM
scmaguigan's Avatar
Default Re: (v4lu3s)
that makes sense .thanks
Addijhaq
Honda Civic (2006 - 2015)
Mar 9, 2011 09:14 AM
Keith_B
Sep 11, 2008 01:39 PM
36Chitownrunnin
Jun 17, 2008 08:44 PM
lifes_simple
Honda Civic (2001 - 2005)
Jan 28, 2007 12:43 AM
PatEJ6
Feb 25, 2003 04:15 AM
