which head would you use?
Old May 21, 2004 | 10:34 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default which head would you use?
well my itr head's cam journals are all scratched up, so i have the choice between a gsr head or a b16 head, both heads i will be putting all the itr internals into along with a new valve job, i can reuse my ctr manifold on the b16 or i can sell that and get a skunk2 for the gsr, which would you do, i have a chipped p28 for an ecu and a jdm itr shorblock
Old May 21, 2004 | 11:11 AM
RTW DC2R's Avatar
b16 and gsr heads are not the same, different combustion chambers. stick with the b16(which is what an ITR head is, correct me if im wrong).
the journals cant be fixed on your head?
Old May 21, 2004 | 12:53 PM
Default Re: (RTW DC2)
no they are aluminum and can not be fixed *what the machine guy around me said**
Old May 21, 2004 | 02:35 PM
vecspeed12's Avatar
Default Re: (coptzer)
right now im currently using a gsr head and its supposed to have a lil bit higher compression. if you go to the cspeed raciing site. theres a little calculator. check it out..
Old May 21, 2004 | 05:50 PM
Bbasso's Avatar
Default Re: which head would you use? (coptzer)
I think you should post some detailed pics up of the questionable area.
There are some pretty smart ***** here
Old May 22, 2004 | 10:54 AM
Default Re: which head would you use? (Bbasso)
the head is already at the machine shop being disassembled, i trust my machinist that its not fixable, the journals are pretty well torn up right next to the cam gear
hialeahzbg
16
Aug 1, 2006 10:57 PM
Viorent Grip! EG
Dec 21, 2005 11:12 AM
EARLdaSQUIRREL
May 21, 2004 11:37 AM
KB96VTEC
Dec 25, 2003 07:00 PM
baonest
Jun 12, 2002 02:37 PM
