JDM B18C w/ LSD - What gear oil to use?
Old May 21, 2004 | 07:49 AM
BOFslime's Avatar
Default JDM B18C w/ LSD - What gear oil to use?
First off, I drive a Subaru, the civic with the b18c is owned by a buddy of mine.
he has no net access, so i told him i'd find out what gear oil he should use.
manuals, and what he's used before is regular motor oil. I thought this odd, but the books do state this.
now with his jdm b18c having a limited slip, the gear oil requirements may change.
IF the lsd is sealed off, then no special oils are required, and the same used on a non lds can be used.
If not sealed off, special additives may be required in order for the lsd to operate correctly.
What weight of gear oil should be used, and is anything special needed for lsd operation?
Old May 21, 2004 | 07:53 AM
Ekasey's Avatar
Default Re: JDM B18C w/ LSD - What gear oil to use? (BOFslime)
2 quarts acura mtl for a type R and top the rest off with GM (general motors) synchro mesh
Old May 21, 2004 | 02:49 PM
RACESMART's Avatar
Default Re: JDM B18C w/ LSD - What gear oil to use? (eLusive ek4)
there is no type r specific tranny fluid, just use acura /honda mtf, they are both the same, i know i work for honda
Old May 21, 2004 | 03:22 PM
TurboTeG4's Avatar
Default Re: JDM B18C w/ LSD - What gear oil to use? (RACESMART)
what the hell is that, so you gotta go to honda, whats the alternative
Old May 21, 2004 | 04:22 PM
RABHonda's Avatar
Default Re: JDM B18C w/ LSD - What gear oil to use? (TurboTeG4)
0w30 oil with friction additive, about 2 ounces.
redline mtl.
Old May 21, 2004 | 08:11 PM
Echo7847's Avatar
Default Re: JDM B18C w/ LSD - What gear oil to use? (RABHonda)
Honda MTF
Old May 22, 2004 | 03:42 AM
Kal's Avatar
Kal
Default Re: JDM B18C w/ LSD - What gear oil to use? (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF </TD></TR></TABLE>
Old May 22, 2004 | 09:08 AM
Ekasey's Avatar
Default Re: JDM B18C w/ LSD - What gear oil to use? (Kal)
wouldnt recomend redklibe everyone that has tried it has had synchro issues
Old May 22, 2004 | 07:12 PM
Dual Cams's Avatar
Honda MTF
710dabber
Mar 26, 2015 04:02 PM
EHondaD6
May 14, 2007 08:38 AM
rocketfuelcerx
Dec 17, 2006 08:22 PM
turbod92hatch
Feb 25, 2003 10:09 PM
DC2R
Aug 14, 2001 04:03 PM
