180whp with this mods ?
Old Nov 7, 2001 | 10:15 PM
SiBirdie's Avatar
Default 180whp with this mods ?
Whats up,
Im going to do a Mild b16a2 set up on my 00 si. Just wanted your guys opinion on this set up since most of you guys are like me. All motor baby! thats what a honda engine is for! well props and cons on this set up . and whp and tq you think i'll put down!
Oversize CTR piston ( 11.1 cr )
Spoon headgasket ( now 11.5:1 CR?) * not sure on this one mb some help ? *
CTR cams
skunk 2 cam gears
B&M fuel regulator
DC 421 header
aem cat back 2.5 pipping
aem cai
Mods that i might add later on
skunk 2 ecu , convert obd 1
Itr valve spring with Ti retainers
skunk 2 cams
better header ? should i get it? If so I might purchase a Jg pro flow header 2.5 collector 421.
thanx for the help guys!
Old Nov 7, 2001 | 10:23 PM
FAST94GSR's Avatar
New User
Default Re: 180whp with this mods ? (SiBirdie)
maybe with the mods you add later on , you'll hit 180 otherwise I dont' think so.
Old Nov 7, 2001 | 10:26 PM
SiBirdie's Avatar
Default Re: 180whp with this mods ? (FAST94GSR)
so what you think i'll make with the mild set up ?
Old Nov 7, 2001 | 10:29 PM
FAST94GSR's Avatar
New User
160's. For the amount of money that you're spending, it would be wise to get a b18c bottom end for more torque. then throw ctr pistons in and do the rest of your mods. that would be a strong street engine with great midrange power.
Old Nov 7, 2001 | 10:31 PM
SiBirdie's Avatar
I was thinking of that. But I was thinkign of doing Ls/vtec instead due to more troque and power.
And about the 160 naw no way. I saw a b16 with basi bolt on plus ctr cams and fuel regulator put down 165whp. So im guessing i'll be close to 180 mark.
Old Nov 7, 2001 | 10:35 PM
FAST94GSR's Avatar
New User
I said 160's I don't like b16's cause they make no torque. 180 hp with only 115-120 ft lbs torque is nothing. Your only making that peak power cause you have to rev the hell out of it.
LS/VTEC would be a good choice. b18a/b's go for cheap.
Old Nov 7, 2001 | 10:37 PM
SiBirdie's Avatar
well making a 180whp b16 will be just fine with me. I dont mind having a torqueless car its a Honda.
Old Nov 7, 2001 | 10:39 PM
SiBirdie's Avatar
but hey thanx for your help though. I'll consider doing ls/vtec. The gain in that motor is sooooo sick mannnn!!!
Old Nov 8, 2001 | 07:00 AM
SiBirdie's Avatar
anyone got any more suggestion ?
Old Nov 8, 2001 | 07:16 AM
Mike K's Avatar
My friend hit 180/119 on a B16A...
CTR pistons, 40 off the head, skunk2 cams, jdm 401, iceman, chipped p28 and open exhaust. with greddy catback he made 174 and 117
mike k
Old Nov 8, 2001 | 07:22 AM
SiBirdie's Avatar
Default Re: 180whp with this mods ? (Mike K)
i heard its bad on the head if you mill it with ctr piston. is it true?
[Modified by SiBirdie, 4:23 PM 11/8/2001]
Eg_TypeR
14
Aug 30, 2006 03:47 PM
civicman3
Apr 12, 2006 08:43 PM
civicman3
22
Mar 20, 2006 08:44 AM
jdmsijdm
Mar 19, 2004 05:56 AM
lopey
Jun 1, 2002 12:15 PM
