91 crx hf rear sway bar
Here is the problem. I have a 91 crx hf and just got a rear disc setup from a teg. I am trying yo figure out where to put the rear sway bar. I see no mounting points for the bar. I heard that I need to weld it in place, and I really do not want to do that. any help would be great.
My wife has a 90 dx that had the same trouble. if you have the brakes mounted bolt up the rear sway bar complete with the body mounts. with the car on the ground mark where the bolt holes line up on the body ( frame rail). Drill 4 holes with a stepped drill bit up to 7/16... then from the inside you will have to punch ( drill) 4 more holes to allow you to drop in a large washer and self locking nut ( or bolt and nut it from the bottom). I have done this and my wifes car has a 22mm rear sway bar and 650 lb rear springs and has had not one problem.. We auto x at least twice a month with this car and this sway bar was put in two years ago... If you want a pic or two drop me a line..
