98 LS swap into 96 HX....Which ECU?
Old May 20, 2004 | 08:27 PM
Earful's Avatar
Default 98 LS swap into 96 HX....Which ECU?
Hey all,
My engine is throwing primary O2 sensor and Fuel pressure sensor codes. The engine runs fine throughout the entire RPM range. It has the 98 LS ECU. Do I need a 96 or 97 ECU for this setup?
Thanks for any help on this!
Old May 20, 2004 | 11:25 PM
MPower332TI's Avatar
Default Re: 98 LS swap into 96 HX....Which ECU? (Earful)
You have the correct ecu. I would check all wiring and check all vacums on the evap canister.
Old May 22, 2004 | 03:23 PM
Earful's Avatar
Default Re: 98 LS swap into 96 HX....Which ECU? (jDmDxTuRd)
Thanks,
I have been told I would need a 96 or 97 ECU. I will check the evap canister.
Earful
mrnicolas
Aug 9, 2013 10:29 AM
HONDCIVIC99
Apr 23, 2011 07:42 PM
projectwidow
Jun 12, 2006 05:20 AM
Red Andy
Feb 9, 2005 04:57 AM
