tranny issues, help please?
Old May 20, 2004 | 06:49 PM
quik sol's Avatar
Default tranny issues, help please?
Alright my friend blew his clutch so we dropped the tranny put in the new clutch and flywheel....we bolted everything back up and started it up...runs fine but it wont go into gear at all. If you start it up in gear it kind of rolls forward a tad bit and stops.....
A friend of mine said it might be a bad slave cylinder but I don't want to buy one and it not be the problem
1995 honda civic dx with sohc vtec swap
Old May 20, 2004 | 06:57 PM
doublejz's Avatar
Default Re: tranny issues, help please? (quik sol)
ok so when the car is running you cant get into any gear? if the car is not running, can you cycle through the gears? I heard of some people putting the clutch in backwards, and those were their symptoms. Did you disconnect the tranny line? could need bleed more.
mpls
Mar 5, 2009 10:26 AM
ogichida
May 11, 2005 10:59 AM
ivanson
Mar 16, 2005 10:58 PM
NewIntegraKid
Mar 25, 2003 10:35 AM
tilt
Oct 7, 2002 01:22 PM
