H22 head???
I'm not an expert on those but I'm pretty sure that won't work.
if a b series head won't fit a d series then that shouldn't as well, at least that's my reasoning. Though I've seen crazier ****.
BTW: SEARCH you'll learn ALOT doing that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S9i1R »</TD></TR><TR><TD CLASS="quote">I'm not an expert on those but I'm pretty sure that won't work.
BTW: SEARCH you'll learn ALOT doing that</TD></TR></TABLE>
You should take your advice before posting a response.
This has been done. More than once.
H and F blocks Do start off identical in the very beginning, and aside from bore and stroke differences, H series receives wonderful FRM and all its glory......
Lots needs to be done to get the frankenstein to work, however. I came across several threads related to this when I had a 5gen accord.
Unless you have a hookup on all the extra band-aids needed to get it running and keep it that way, it may almost be cheaper to get a complete swap.
Menf22acb1e
Jul 26, 2018 07:11 AM
Cidone
13
Jun 27, 2006 11:08 PM
