2nd gen ls integra brake booster & MC for 92 eg with gsr 4 disc swap??
i already searched and all mentioned using 94+ rs non abs BB & MC for the brake swap. Any you guy have done or know if a 90-93 integ BB/MC will work on 92 civic dx with full gsr brake swap? thanks
i just did a si rear brake swap on my 98 ex and the original master cylander works fine on mine. all you should have to do is add a little more brake fluid to make up for the extra that disc calipers use.
You could always get a 89 accord lxi if you want a 15/16 mc They are like 60 bucks at autozone and bolt right up without changing brake booster.
DEF
DEF
RuckRider2
May 3, 2017 03:31 PM
