Oil Pressure Gauge Help
Old May 20, 2004 | 03:32 PM
milton's Avatar
Default Oil Pressure Gauge Help
I have a electrical gauge i just got off of a member here. I need to know how to install these? it has 3 screws in the back. Im not sure which is which. Has anyone installed these? I have used the S E A R C H Tool and havent found one decent installation advice here. can you help thanks in advance
Old May 20, 2004 | 11:22 PM
Davesgarage831's Avatar
Default Re: Oil Pressure Gauge Help (milton)
Is it a Autometer gauge?
Old May 21, 2004 | 02:54 PM
milton's Avatar
Default Re: Oil Pressure Gauge Help (Davesgarage831)
yes it is
Old May 21, 2004 | 06:31 PM
APEX CRX's Avatar
1 is ground, 1 is 12v switched power, and the 3rd is for the sender. you can either tee off the factory sender (next to oil filter), tap inot the oil pan or get a VDO drain plug with the sender in it.
Old May 21, 2004 | 07:16 PM
sporkcrx's Avatar
Default Re: Oil Pressure Gauge Help (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">1 is ground, 1 is 12v switched power, and the 3rd is for the sender. you can either tee off the factory sender (next to oil filter), tap inot the oil pan or get a VDO drain plug with the sender in it.</TD></TR></TABLE>
oil pressure, not temp
Old May 22, 2004 | 06:21 AM
doublejz's Avatar
Default Re: Oil Pressure Gauge Help (sporkcrx)
just T it off the back of the block. Acutally run a line from the block to the firewall and fasten the T to the wall. Then go from there. For those temp probes in the drain plug you gotta watch those, they hang lower then a normal one, which may cause some problems due to the position of the drain plug, and ground clearance
Old May 22, 2004 | 04:30 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">
oil pressure, not temp </TD></TR></TABLE> ha ha my bad, It would of helped if I actually read the question
pcguy760
Jul 2, 2006 10:17 AM
standbackimapro
Apr 30, 2006 07:22 PM
CivicMike
May 26, 2005 09:34 AM
RICEBURNER1406
May 8, 2002 08:09 PM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
