New skunk2 Stage I, II, II cam specs
Old Nov 7, 2001 | 07:52 PM
TRuST's Avatar
Default New skunk2 Stage I, II, II cam specs
Skunk2 cams
Stage I
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.9 mm, duration 249 @ 1mm
Stage II
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Stage III - This things are huge
INTAKE lift- 12.7 mm, duration 273 @ 1mm
EXHAUST lift - 11.5 mm, duration 273 @ 1mm
Old Nov 7, 2001 | 07:54 PM
555R's Avatar
Default Re: New skunk2 Stage I, II, II cam specs (TRuST)
i didnt know skunk made more than one cam
big lift but where is the duration? not that much there
I know Jun 3s are like 304 degrees and 12 mm lift
Toda C is 12.5mm but not sure of duration
Old Nov 7, 2001 | 07:59 PM
TRuST's Avatar
Default Re: New skunk2 Stage I, II, II cam specs (555R)
They release them at SEMA.
Here's the orginal post.
https://honda-tech.com/zerothread?id=85493
Toda Spec C's specs
Toda C's
INTAKE lift - 12.5 mm,duration - 255 @ 1mm
EXHAUST lift - 12.5 mm, duration - 255 @ 1mm
Old Nov 7, 2001 | 08:05 PM
555R's Avatar
thats interesting...
i might have to get a set for the shop for testing purposes
Old Nov 7, 2001 | 09:45 PM
ImportReview
Guest
Posts: n/a
Skunk 2 is bad ***.
Damn...those Type 2's look bad ***.
Perfect.
Smart company. Them and JUN are one of the few companies to figure out you dont need a HUGE exhuast cam at all....
Jeff
Old Nov 7, 2001 | 09:51 PM
FAST94GSR's Avatar
New User
Default Re: New skunk2 Stage I, II, II cam specs (ImportReview)
Looks like I gotta trade my Skunkies for some Skunk Type 3's!
Jeff you needs to do some testing!
FYI: Skunk2 will be racing next year in a 2002 RSX. They'll be looking to break some new records. Stay Tuned!
Old Nov 8, 2001 | 06:37 AM
Mike K's Avatar
Default Re: New skunk2 Stage I, II, II cam specs (FAST94GSR)
Yes.. I have been doing a little cam-comparison testing on the dyno.. in my spare time. So far, the Spec A's were the best.. even better than Spec B.
But I just installed a JUN2 intake cam and ITR exhaust cam this past week. Man, this setup kicks ***. Feels the best out of ALL the cams I have tried so far.
Big intake cam, no so big exhaust cam.. seems to work well.
Can't wait to dyno.
Old Nov 8, 2001 | 06:49 AM
FSTASNTZ's Avatar
Ummm, I thought the Cs were 12.5 MM and 295 duration.
Like this for all three lobes:
250 (11.0) 295 (12.5) 250 (11.0) I
250 (11.0) 295 (12.5) 250 (11.0) E
Jason
Old Nov 8, 2001 | 06:52 AM
fastbrakes's Avatar
I think the JUN cam specs are at gross lift, while the Skunks are at 1mm lift. You should always use the lift/duration specs at the checking height as this takes all the clearances out of the play. It gives a much better read on the cams true specs...
Old Nov 8, 2001 | 06:57 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: New skunk2 Stage I, II, II cam specs (FSTASNTZ)
Come on you guys should know the difference between advertised duration (duration at zero lift) vs. duration at 1mm lift (japan/honda), vs. duration @ .050" lift (common US cam spec). But still the duration still don't tell you jack about the ramp rates. If you look at Skunk2 I cam vs. CTR/ITR you'll see why Skunk said it works fine against the stock valve train. Although it opens the valves as fast as it could just like R cams when it gets to the top it is much softer.
The Skunk2 III cams are indeed huge. Even longer duration than JUN III's.
Old Nov 8, 2001 | 10:36 AM
Mike K's Avatar
Default Re: New skunk2 Stage I, II, II cam specs (frank@b16a.com)
Looks like the Skunk2 Stage III cams will be nice.
Hopefully Skunk doesn't **** em up and do huge primary lobes..
Old Nov 8, 2001 | 11:57 AM
ImportReview
Guest
Posts: n/a
Default Re: New skunk2 Stage I, II, II cam specs (Mike K)
Mike K. I have been blabbing about that big cam intake, stock cam exhuast for eternity..and all I get is "toda rules" BS.
I am so glad you tested it. People need to know. Saves money.
ANd yes, modifying primary lobes to be huge is probably the worst design flaw in some brands of cams...
Good going Mike K.
Kick ***.
Jeff
Old Nov 8, 2001 | 12:12 PM
B18CXr's Avatar
yeah, I sure do hate my off Vtec power
jack (Toda owner)
[Modified by B18CXr, 4:31 PM 11/8/2001]
Old Nov 8, 2001 | 12:16 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: New skunk2 Stage I, II, II cam specs (B18CXr)
LOL
Old Nov 8, 2001 | 12:34 PM
Mike K's Avatar
[QUOTE] yeah, I sure do hate my off Vtec power
QUOTE]
yea.. i know.
you should try jun2 and see how your off-VTEC power is.
you'd be surprised.
Old Nov 8, 2001 | 12:39 PM
B18CXr's Avatar
point taken.
If your happy, Im happy it's really that simple. Jun for some Toda for others.
Old Nov 8, 2001 | 12:44 PM
Mike K's Avatar
agreed, Jack.
i'll have some dyno plots soon.
one is of my motor with the following cams tested... jun2, spec A, spec B, ctr
other is of my friend's motor with 12:1 compression.. spec A, spec B, jun3
the results were unbiased, and you'd actually be surprised which one got the award for "off VTEC power"
stay tuned....
Old Nov 8, 2001 | 12:50 PM
FAST94GSR's Avatar
New User
post them up ASAP.
When I'm racing I stay on the mid-high lobes. I don't race at 3,000 rpm. 7-9 grand more like.
Old Nov 8, 2001 | 01:01 PM
B18CXr's Avatar
for those of us that don't race in a straight line and don't have extra trannys to go with each track we race on, you will have to adjust revs and shift points for various turns.
Old Nov 8, 2001 | 01:14 PM
Back in Black's Avatar
Rather OG
I just spit all over my keyboard reading this thread...
I've got to agree with Jack. Straight line racing sucks...turns are where it's at
VIR like Visa- "It's everywhere you want to be"
Old Nov 8, 2001 | 01:19 PM
FAST94GSR's Avatar
New User
Just got off the phone with Skunk2, the type 3's aren't for street engines, they're for purpose built racing engines only. Just fyi.
Old Nov 8, 2001 | 01:26 PM
TRuST's Avatar
Default Re: New skunk2 Stage I, II, II cam specs (Darth VadeR)
Old Nov 8, 2001 | 01:27 PM
b00st-0wnz's Avatar
I think I hear some Banjos playing....
Old Nov 8, 2001 | 01:39 PM
Misfit's Avatar
Can't wait to dyno.[/QUOTE]
I was going to try that on my CRX befor it got stolen. Can't wait to see some dyno results.
Old Nov 8, 2001 | 02:27 PM
bhcvc's Avatar
I don't remember the specs for Skunk's previous cam, but I'm assuming it's now called their Stage I cam?? For those who have the Stage I (their previous only cam offerring) cam, what's your VTEC activation point set at? What CR are you running with them? Thanks.
