Sevice Connector in 2000 civic Si
I searched on H-T and other sites, and I can't find the 2-pin service connector in my car. I looked right where the ECU is and above it and I can't find any connector just hanging with a green cover on it. I tried to look right under the glove compartment and I still can't find it. I read the ECU sticky and I can't find it still. Where is it located at in a 2000 civic Si?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb »</TD></TR><TR><TD CLASS="quote"> and it's a grey connector with two pins right?
Some are grey, most are blue. It should be next to a three pin blue connector.
I don't recall if it's right near the ECU, or a bit higher near the glove box, but it shouldn't be too hard to spot. And yes, it may or may not be grey, but there aren't any other 2-pin connectors in that location. I'm also not certain whether this applied to my Integra or the Civic, but one vehicle had the connector "plugged in" to a rubber protector.
fking sad fellas...
ecu.. look towards the back side. green rubber boot. has two wires going into it.. pull it out soflty. blue plug.
thats the service connector..
your check engine or srs light will flash the codes..
this thread has been OWNED by me...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hiddenEM1 »</TD></TR><TR><TD CLASS="quote">this thread has been OWNED by me...</TD></TR></TABLE>
Double
Double
marks_lude
Feb 19, 2009 01:44 PM
) its hidden behind the kick panel sometimes...you gotta dig for it
