Brand New OEM Honda pistons For Sale!
Old May 20, 2004 | 01:23 PM
RABHonda's Avatar
Default Brand New OEM Honda pistons For Sale!
P29's still in box, .50mm over. Sets include rings, and pins. I can also get the flat-top PM3's, which are actually my preferred piston for a d16 build. These are also .50mm over, sets include rings, and pins. I'm asking $160.00 /set.
I can get PR3 and P61 pistons, over-sized .50mm, with rings and pins for $170.00 /set. The PR3 pistons have a mild dome, while the P61 pistons are flat-topped, which is the most efficient piston design.
Have 1 set of .50mm over CTR pistons on the shelf. These pistons are slightly stronger than other B-Series pistons, with a molybdenum coating for reduced friction/operating temperature. These also come with rings and pins. Asking a mere $280.00 for this set.
*I can balance the pistons for $5 /piston extra. Since only a possible 3 pistons would need to be reduced in weight, the total charge for such a service would be $15. These would be measured to within a tenth (0.1g) of a gram of each other.
** Shipping is extra.
Old May 21, 2004 | 09:21 PM
RABHonda's Avatar
Default Re: Brand New OEM Honda pistons For Sale! (RABHonda)
Old May 21, 2004 | 10:12 PM
boredracer408's Avatar
oem
Old May 28, 2004 | 12:06 AM
ceLtic's Avatar
N/A wh0re!
Default Re: Brand New OEM Honda pistons For Sale! (boredracer408)
still got the p29 pistons? will they work with stock bore fugger?
Old May 28, 2004 | 07:48 AM
RABHonda's Avatar
Default Re: Brand New OEM Honda pistons For Sale! (ceLtic)
no more p29's, but i have the pm7 piston which is the exact same. i can get them in stock size or over.
Old Jun 7, 2004 | 07:56 PM
infamousR13's Avatar
I would like a set of the +.50mm PR3's with rings and balanced. PM me on how to buy.
Old Jun 7, 2004 | 08:15 PM
RABHonda's Avatar
Default Re: Brand New OEM Honda pistons For Sale! (infamousR13)
man, this PM isnt coming up and your email address is off.
email me as soon as you get this, rabenton81@yahoo.com
Old Jun 10, 2004 | 08:05 PM
ceLtic's Avatar
N/A wh0re!
still got the pm7's in stock bore?
and would they fit into a d16z6?
Old Jun 11, 2004 | 06:16 PM
RABHonda's Avatar
yeah, i have some pm7's in stock bore, but id rather sell you .5mm oversized because i highly recommend you get the block bore/honed so you dont run excessive piston-to-wall clearance. but in the end, its your call.
let me know, i have them, whichever you would like.
thank you.
Funkster
Oct 11, 2015 01:59 PM
Dc4LsTeG
Jul 6, 2012 11:16 PM
JIDUM_Undercover
Mar 3, 2005 08:19 AM
