Intake preference for B16A EF's?
Old Nov 7, 2001 | 07:24 PM
HyperREV's Avatar
New User
Default Intake preference for B16A EF's?
im currently running an AEM on my b16... and am contemplating swapping with a friend for a 3" shorty.
reason being is the AEM looks hella small for the b16 at 2.5"
im also running a larger TB (68mm intake 62mm exit, 9 degree taper)
i've heard i'll lose a bit of bottom end, wich doesnt really bother me if im gainging it back in the top end.
any B16A EF owners here have experience with both??
if it matters i plan on running '01 R cams next season
any input would kick ***
Old Nov 14, 2001 | 11:22 AM
Lsos's Avatar
Default Re: Intake preference for B16A EF's? (HyperREV)
Supposedly the 2.75in 2000 Civic Si AEM intake it the proper one to use on a b16. A reputable guy on the crx resource tried it and said it made a big difference.
You have to do something about the battery, though. He got some tiny optima battery, or something like that.
Old Nov 14, 2001 | 11:39 AM
91sifreak's Avatar
New User
Default Re: Intake preference for B16A EF's? (Lsos)
yes that is true, but the only thing is, minor thing, you either have to lower the battery tray or put the battery in the trunk. But have that setup and we look at the 99-00 Si intake and it will work perfect.
Old Nov 14, 2001 | 12:18 PM
headhunter's Avatar
Default Re: Intake preference for B16A EF's? (91sifreak)
i've only heard of people relocating the battery, but i never thought of lowering the batttery tray, have you seen anyone do this, i'd rather do this than put it in the back. i'm wondering if their is clearance problems at all. if you know someone who did that let me know
Old Nov 14, 2001 | 12:42 PM
SiR Kid's Avatar
New User
Default Re: Intake preference for B16A EF's? (bbcrx)
How can you lower the battery? The distributor it too close to the frame rail, and the trans is just under the tray...
Mine's in the trunk.
Old Nov 14, 2001 | 01:01 PM
crxgurlllll's Avatar
Default Re: Intake preference for B16A EF's? (SiR Kid)
use a smaller tractor type battery...the car runs off the alt anyways onces its started......Unless youre in a cold climate where its hard to start a car then this should work...
Old Nov 17, 2001 | 06:50 AM
crxsi42069's Avatar
look into the iceman its a choice of few but its good
Old Nov 17, 2001 | 10:34 PM
Phatwhippin_CRX's Avatar
Default Re: Intake preference for B16A EF's? (crxsi42069)
'99-00 Civic Si, just relocate the battery to the trunk
Old Nov 18, 2001 | 03:27 AM
HyperREV's Avatar
New User
Default Re: Intake preference for B16A EF's? (Phatwhippin_CRX)
anybody here running a 3" short ram on their B16?
Old Nov 18, 2001 | 01:47 PM
88 CRX SiR's Avatar
I'm running a cheapo 3" short ram type intake with custom cold air ducting. (scoop under front bumper) The battery is relocated in the rear, this was all done by the previous owner.
Old Nov 19, 2001 | 03:39 AM
HyperREV's Avatar
New User
Default Re: Intake preference for B16A EF's? (88 CRX SiR)
how do you find the power delivery?
btw do u have icq?
always nice to have another B16 crx owner from BC on my list
[Modified by HyperREV, 4:39 AM 11/19/2001]
Old Nov 19, 2001 | 05:27 AM
88 CRX SiR's Avatar
Can't really say how the power delivery is since this is my first encounter with VTEC. For what it's worth, when VTEC kicks in, I can slam myself back into my seat easily at WOT all the way down to 8k rpm. Below VTEC, it feels just like any other HONDA at low revs...not sure if that helped.
Yeah, I do have ICQ, but I don't use it much. PM me with your ICQ, we can talk after.
Old Nov 19, 2001 | 05:40 AM
91sifreak's Avatar
New User
THis weekend I bought a 99-00 Si AEM intake and it fits just fine, didn't have to move the battery to the truck, just bent the end of the tray so there ws no more lip and extended the tray to the front of the car so the battery sitsa closer to the front of the car. It works beautifully, a little bit more torque on launch aswell. Nevermind about dropping the tray down, you would have to cut it in half them use a smaller cell battery, like a tractor one, to much work. THe 99-00Si one is also the same bore size as the throttlebody inlet, so it works great.
Old Nov 19, 2001 | 09:21 AM
wuhungsixxx's Avatar
New User
would u guys say that a 99-00 SI CAI would work for my b18c w/ skunk2 intake manifold in my crx...i have asked this question before and i think thats what someone said i shoudl do...anyone have this setup?
Old Nov 19, 2001 | 11:23 AM
91sifreak's Avatar
New User
Default Re: Intake preference for B16A EF's? (wuhungsixxx)
don't know, wait your using the skunk2 for the b18c or for the ITR? The reason i ask is due to the location of the throttlebody, I think the t/b sits lower with the b18c due to the secondary butterflies kind of tunr the manifold the other way of the itr and stock b16a manifolds. I have the skunk2 for my b16a and it works nicely, no modifcation except the battery tray.
Old Nov 19, 2001 | 11:59 AM
New User
the manifold from skunk2 that im using is a basically a copy of the type r manifold...it there for eliminates the secondary butterflies...
Old Nov 19, 2001 | 12:58 PM
91sifreak's Avatar
New User
then that should work, just move the battery forward and all is good.
Old Nov 19, 2001 | 02:02 PM
New User
thanks...do i have to cut the hole a lil bit bigger for the piping to make it through into the bumper from the engine bay?...
Old Nov 19, 2001 | 04:00 PM
HyperREV's Avatar
New User
cool thanx, thats pretty much what i was lookin for
damn that means i hafta buy another AEM...
Old Nov 20, 2001 | 05:49 AM
91sifreak's Avatar
New User
Yeah the bigger intake will fit and all but i did have to widen the hole where the filter sits behind the bumper. Nothing a pair of tin sheers can't handle. Only cut enough to get the pipe though, then you can use a self tappiong metal screw and then you can actually use that mounting bushing that comes with it. Tap it into the frame rail and then take that out and the mount bushings will pull nice and tight. Good luck
Old Jun 22, 2003 | 03:49 AM
Garrett's Avatar
Civic Si 99-00 Cold AIr INtake
Old Jun 22, 2003 | 05:20 AM
primoEF's Avatar
Default Re: Intake preference for B16A EF's? (Garrett)
here is mine, J's carbon intake with Skunk2 IM
Old Jun 22, 2003 | 05:23 AM
slywfbpsi's Avatar
mine is the old one piece cai for the 99-00 si, sitting in my garage until I get the rest of my parts.
Old Jun 22, 2003 | 06:23 AM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91sifreak &raquo;</TD></TR><TR><TD CLASS="quote">THis weekend I bought a 99-00 Si AEM intake and it fits just fine, didn't have to move the battery to the truck, just bent the end of the tray so there ws no more lip and extended the tray to the front of the car so the battery sitsa closer to the front of the car. It works beautifully, a little bit more torque on launch aswell. Nevermind about dropping the tray down, you would have to cut it in half them use a smaller cell battery, like a tractor one, to much work. THe 99-00Si one is also the same bore size as the throttlebody inlet, so it works great.</TD></TR></TABLE>
can you post some pictures, im curious to see some pics of the way you have it all set up.
Old Jun 22, 2003 | 11:13 AM
Ef Whore's Avatar
Default Re: Intake preference for B16A EF's? (slowpokesi)
Im not flaming, but what is the point of a J's intake that big? Seems like it would kill bottem end.....
