will ek suspension fit into an eg hatch?...searched
Old May 20, 2004 | 09:36 AM
Bigjussin's Avatar
Default will ek suspension fit into an eg hatch?...searched
anyone know off the top of their head......will suspension off a 97 dx coupe fit into a 93 vx hatch?
tia
Old May 20, 2004 | 09:44 AM
TurboEH2's Avatar
Default Re: will ek suspension fit into an eg hatch?...searched (Bigjussin)
which componets are u refering to????
Old May 20, 2004 | 09:46 AM
Jon V's Avatar
Default Re: will ek suspension fit into an eg hatch?...searched (VTECschmetec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECschmetec &raquo;</TD></TR><TR><TD CLASS="quote">which componets are u refering to????</TD></TR></TABLE>
Old May 20, 2004 | 04:53 PM
Bigjussin's Avatar
Default Re: will ek suspension fit into an eg hatch?...searched (Jon V)
springs and struts
Old May 20, 2004 | 04:56 PM
WhiteEG6's Avatar
springs will work. front shocks will work, rears will not, unless you change the rear LCA on the EG to the EK units
Old May 20, 2004 | 05:10 PM
slammed_93_hatch's Avatar
Default Re: (WhiteEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteEG6 &raquo;</TD></TR><TR><TD CLASS="quote">springs will work. front shocks will work, rears will not, unless you change the rear LCA on the EG to the EK units</TD></TR></TABLE>
worng. if you do that your rear alignment wil be fuckered up.
they only thing you have to do is grind down the metal were the strut goes. (on the LCA). or maybe its the EK strut that is bigger.
any case it will work.
DO NOT USE EG or DC LCA's on an EK and do not use EK LCA's on a EG/DC.
Modified by slammed_93_hatch at 9:40 PM 5/21/2004
Old May 21, 2004 | 01:36 AM
TurboEH2's Avatar
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
DO NOT USE EG or EC LCA's</TD></TR></TABLE>
what he said
Old May 21, 2004 | 08:11 AM
Bigjussin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">worng. if you do that your rear alignment wil be fuckered up.
well the car is a 93 hatch...should i not use the stock lca's or am i getting confused
Old May 21, 2004 | 09:34 AM
HyBriDcxR's Avatar
Default Re: (Bigjussin)
I don't know what the guys above me are talking about.
I'm using EK rear shocks with my eg lca right now. NO problems here.
And my friend is using eg rear shocks on his EK.
Front shocks for eg and ek are the same.
Old May 21, 2004 | 12:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteEG6 &raquo;</TD></TR><TR><TD CLASS="quote">springs will work. front shocks will work, rears will not, unless you change the rear LCA on the EG to the EK units</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HyBriDcxR &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what the guys above me are talking about.
Front shocks for eg and ek are the same.</TD></TR></TABLE>
thats what im talking about i just got part of it backwards. EG/DC LCA ARE NOT INTERCHANGEABEL WITH EK LCA. White EG6 said to use EK LCA.
i thought it was all going onto an EK
Old May 21, 2004 | 02:48 PM
Jonas99's Avatar
assuming LCA and mount points are the originals:
springs and struts are interchangeable. my tokico's and skunk2's are for 92-00 civics.
Old May 21, 2004 | 05:09 PM
moto27cm's Avatar
they only thing you have to do is grind down the metal were the strut goes. (on the LCA). or maybe its the EK strut that is bigger.</TD></TR></TABLE>
The EH/DC shock mount bushings are 10mm wider than the EJ. It would be easier to buy EJ shock mount bushings than to grind the existing bushing down to size, making sure you grind the same off both sides of the bushing. They are both the same diameter.
Old May 21, 2004 | 08:13 PM
dantastic's Avatar
Default Re: (Jonas99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonas99 &raquo;</TD></TR><TR><TD CLASS="quote">assuming LCA and mount points are the originals:
springs and struts are interchangeable. my tokico's and skunk2's are for 92-00 civics.</TD></TR></TABLE>
half right. some companies sell the same rear shock for 92-00 civics, as they include washers to make up for the different width of the lower LCA bushing. its easy to put a EG shock on an EK, as u just put 2 washers in to make up the extra gap due to the larger EG lower fork. however, most companies make different applications for EK and EG rear shocks. i.e. my agx are made for an EK, but i have them installed on my EG. i had to machine a couple mm off each side of the rear LCA bushing to get them to fit.
Old May 21, 2004 | 08:26 PM
Chickenball's Avatar
Default Re: (dantastic)
I called Tokico to order some of the top mount adjustable ***** and I asked this same question. Will EK shocks front and rear fit an EG? The answer I got from Tokico was that they WILL! I was told that the difference is that spacer that was mentioned in the above. Also just to note. If you are really nice to the Tokico people, they will send you free adjustable *****! Tokico
Old May 21, 2004 | 09:47 PM
fishnfst's Avatar
Tokico sells the same shock for eg's and ek's. Koni makes a ek and eg specific rear shock. EK rear lca's are narrower at the lower mount point. Eg's rear lca's are wider at the lower mount point. Tokico includes spacers with all of their rear shocks for this reason. I am using 96 gsr rear lca's in my ek and they are working fine. What kind of alignment problems were you having?
Old May 22, 2004 | 10:40 AM
moto27cm's Avatar
Default Re: (fishnfst)
If you were using Teg LCAs on your EK, you would have major positive camber. MAJOR! Its possible that youre using 99/00 Si LCAs. I did a study on rear LCAs. Here:
PatrickFrantz
May 27, 2008 11:03 PM
gsronhatch
Nov 15, 2006 09:05 AM
skoolz4loserz
Suspension & Brakes
10
Nov 3, 2005 06:04 PM
Race Egr
Suspension & Brakes
Apr 18, 2005 08:36 AM
chad
Dec 15, 2003 01:21 PM
